Author Topic: how many times does it take to clean your carbs so you can ride?  (Read 6533 times)
should be a poll but no one really responds to them,,,how many times do you have to remove and clean your friggen carbs???fark!!!cant you all do it once and be done??it only takes once.,,do it once ,,do it well.,,,,oh hang on,,i might have missed a bit of crud,,,oh???i didnt pull the slow jets,,,hey whats this long tube with holes along its length?is it some kind off emulsifier?i dropped the bowls and they looked clean etc.,,i dont want no excuses.
edit on purpose,,the points were dirty or some other #$%*.
 i had it on reserve as i knew it was low on fuel.
my fuel line was kinked.
i had a bad condesor it turns out
whos pulled carbs here over and again to find its something else??come on now,,own up!!!
« Last Edit: June 15, 2012, 02:23:39 AM by dave500 »
Offline chewbacca5000
  • I polish covers!
Re: how many times does it take to clean your carbs so you can ride?
« Reply #1 on: June 15, 2012, 04:51:13 AM »
Hey Dave,
Gotta say I am guilty of trying the carb spray clean while on the bike underestimating the effect 40 years can have on a set of carbs.  Most carbs upon detailed inspection will have some level of corrosion even if it is just the t connector.  I don't like separating the racks as I have to readjust the choke linkage, but going forward it's complete disassemble for me.
Offline lrutt
« Reply #2 on: June 15, 2012, 04:56:52 AM »
No short cut on carbs. If you have a lot of experience you get to the point that it's just a one time thing. They can never be too clean. Air and carb cleaner are your friends as are very very small probes to clean those small openings without damaging the jets etc. Rarely do I have to buy new parts, just clean old ones.
« Reply #3 on: June 15, 2012, 05:33:03 AM »
I kept pulling them and cleaning but what made a difference was:
- rebuild kits to replace worn parts
- finding and cleaning the passage to idle jet
After that she was eager to run and it was just matter of tweaking.
But it took me many tries to get there.
Offline jstfkndi
« Reply #4 on: June 15, 2012, 05:40:13 AM »
Working on mine for real for the first time. Hoping to keep them ON the rack for this, but have a rebuild kit and I don't mind taking off the carbs....it's the freaking air box I hate trying to get on and off!! Is there some trick I'm missing or is it just bend and squeeze that thing in any way you can? Not going to get ahead of myself with the rebuild, but I am being meticulous as I don't want to do this again.
Offline samIam
  • 72 Honda CB500 Four
« Reply #5 on: June 15, 2012, 06:07:13 AM »
Pulled mine twice.  First time, I didnt clean the slow jets good enough and idle was bad.  Second time, got it right.  Live and learn.
Offline DJ_AX
« Reply #6 on: June 15, 2012, 06:10:36 AM »
"how many times does it take to clean your carbs so you can ride?"
"the world may never know"
Offline Lostboy Steve
« Reply #7 on: June 15, 2012, 06:16:35 AM »
lol perfect topic I'm on my 3rd complete rebuild in 2 months. I guess I missed something.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
bollingball
« Reply #8 on: June 15, 2012, 07:36:57 AM »
Same here. But read the manual (Honda) it says the slow jets are non removable.  !978 750K. So do I get a pass. or go to carb rebuild jail ;D
Ken
« Last Edit: June 15, 2012, 08:20:14 AM by bollingball »
Offline Really?
« Reply #9 on: June 15, 2012, 07:47:34 AM »
In short, until you get it ALL right.  I pulled my carbs off a few times to clean.  They would get dirty right after each cleaning.  Eh you say?  Yup, dirty right after being cleaned.  It took me a while to figure out that the PO's tank liner was melting and flowing with the gas right back into the carbs.  After all that was fixed, then I noticed the fuel lines were deteriorating from the inside, little black dots holding the float pins open.  All fixed now, clean and no leaking carbs.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline 750K
« Reply #10 on: June 15, 2012, 08:46:06 AM »
Once if you do it right.
77 Cb750, 78 Kz1000
Offline grachman
« Reply #11 on: June 15, 2012, 09:12:40 AM »
Hahaha!  I learned from hearing my old man cursing after removing carbs multiple times.  After the 3rd or 4th time, he would usually drop them on my lap and tell me to do it.  His eyes weren't so good.  I learned pretty early to be thorough with carbs.
Glenn
"wake me up when we're all nomads again."
1974 CB550
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: June 15, 2012, 09:27:33 AM »
Three times with the carbs completely off the bike and once by taking off the float bowls and clearing out the pilot jets after sitting all winter. Runs like a champ now.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: June 15, 2012, 09:28:20 AM »
You're just a special kinda guy  :o
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline harisuluv
« Reply #14 on: June 15, 2012, 10:39:47 AM »
Just one time now but when I first started there were redos.  Now I just go all the away apart and soda blasted and the whole deal. If they are for myself or I am just trying to get a bike running I don't always polish them so it can be done a little quicker. When it comes to carbs I think of "Aliens" when Ripley says "...nuke the entire site from orbit. It's the only way to be sure.."
Offline fmctm1sw
« Reply #15 on: June 15, 2012, 11:00:19 AM »
It depends on how dirty your gas tank is.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Scott S
« Reply #16 on: June 15, 2012, 12:37:41 PM »
 Clean them, then clean them again. When you think they're REALLY clean, clean 'em again.
 So, to answer your question: Somewhere between 3 and 737 times.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #17 on: June 15, 2012, 01:02:22 PM »
Took me two times on my CB, I learned my lesson and the VFR carbs only took the first try.
Offline lucky
« Reply #18 on: June 15, 2012, 01:13:08 PM »
BINGO!!!! We have a winner!!!
« Reply #19 on: June 15, 2012, 01:22:29 PM »
...Dave, it's probably 'cuz everybody on here keeps trying to use all this weird stuff that wasn't designed for carb cleaning to clean their carbs, like simple green(an excellent degreaser, haven't seen too many carbs full of grease), pinesol(that stuff barely does anything to my kitchen sink), lemon juice?...etc.  yeah, maybe that stuff will work, but if you go to an auto parts store, they have this stuff called "CARBURETOR CLEANER"...
« Reply #20 on: June 15, 2012, 01:44:35 PM »
Yep    ;)
« Reply #21 on: June 15, 2012, 01:46:44 PM »
Upon scrutiny, the question is flawed.
If the carbs are clean, you are done.
If you go though a substandard or cursory cleaning process, many cleaning cycles can still result in problems.
You got that right.  But, it must be fun to reinvent the wheel, or cheat one chemical manufacturer to pay another.
I expect these same people have divots all over their wrenches from using it as a hammer.   ;D ;D
The right tool (and a bit of knowledge) can make all the difference.
Offline Bailgang
  • Scott
  • Indiana
« Reply #22 on: June 15, 2012, 02:37:33 PM »
At least 4+ times but but the first 2 tries were a must. When I first started the carbs were so gummed up with varnish I had to boil them in hot water to loosen the slides enough to get them out as well as the float pins because the floats were froze too but that's just the half of it. It was the countless jet changes, needle jet changes, needle jet height adjustments in an effort to figure out why it seemed to run lean. That turned out to be carb boot clamps that weren't tight enough and I swear I had checked for vacuum leaks before. Once I figured that out and replaced the manifold "O" rings, that's when the carbs started responding like they should.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #23 on: June 15, 2012, 02:38:06 PM »
Once for me, but I was extremely thorough and ridiculously meticulous. 38 year old 550 runs like new, so the effort was well worth it.
Offline chase2034
« Reply #24 on: June 15, 2012, 02:50:37 PM »
How many times does it take to clean the carbs? Zero for me . I use sea foam with every tank.
