Author Topic: Need help (little help)  (Read 1646 times)
Offline lucky
« on: June 15, 2012, 02:00:14 PM »
I need ONE float bowl screw for the 1969-1970
CB750 carbs.
I will pay.
Photos of the carbs.
CLICK once to enlarge photo.
Offline adamlwvdc36
Re: Need help (little help)
« Reply #1 on: June 15, 2012, 02:38:11 PM »
these are metric screws... go to a hardware store and buy them... they will come in sets of 5 probably for 2 dollars.  take it with you to match it up.
_ADaM
Be a COWBOY, not a NERD!  youre riding an antique bad ass motorcycle for God's sake...
75 CB550 Named "Don Casper"  Don for grandpa, Casper for the guy that mentored me to riding... RIP Kenny...
Offline lucky
« Reply #2 on: June 15, 2012, 03:05:45 PM »
I know that I can do that but I want the drain screw to work properly. The drain screw has a hole drilled through it and another hole that is transverse. It is so the float bowl can drain without taking the screw al the way out.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: June 15, 2012, 03:18:13 PM »
If it helps any (I have '69 K0) that drain hole in the screw is of little advantage. If you drain the bowl(s) using that method, leaves a small amount of fuel at the bottom of the bowl which quickly evaporates and leaves a varnish build-up. I always remove the entire screw when draining the Caribs.
Offline lucky
« Reply #4 on: June 15, 2012, 04:38:33 PM »
Thanks for the suggestion. When it comes winter I will use that method.
72500john
« Reply #5 on: June 15, 2012, 05:17:26 PM »
do you have another drain screw of similar style that you could drill in the same fashion?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: June 15, 2012, 06:17:43 PM »
Keep an empty tuna can around. Fits neatly under the Caribs and catches the screw and the gas.
Offline wrenchmuch
« Reply #7 on: June 15, 2012, 06:47:12 PM »
I have some screws from later carbs. They are pre 75 screw tops but they aren't k0 carb screws.
CB750K1
CB750K4
« Reply #8 on: June 15, 2012, 06:57:41 PM »
When I put a bike in storage,and thank goodness the 750's have the clip,I just pull the whole bowl and dump as well as making sure no more gas leaks in. A friend of mine with many bikes keeps the float bowls off the whole time the bike may be layed up.That drain screw with the gasket though is a specialty item I think,never tried getting one down at the Ace Hdware store ?
