Author Topic: wiring 550 1975  (Read 1130 times)
jontc
wiring 550 1975
« on: June 17, 2012, 07:42:49 AM »
I have no headlight.Brake light works with foot brake,was on and brake now only brake.Front turn signals stay on rear ones only work when using turn sigs.The alarm works and the turn signal light works.The wiring harness was in perfect shape,no broken wires.checked fuses.everytime i blink i only see colored wires.i will put up some pictures later,just needed to walk away for now.Any thing i might have missed?
Offline LesterPiglet
  • 1977 CB550F2
Re: wiring 550 1975
« Reply #1 on: June 17, 2012, 07:48:41 AM »
Yes, a better description. I'm sorry but the info given doesn't help much.
jontc
Re: wiring 550 1975
« Reply #2 on: June 17, 2012, 07:54:53 AM »
i will do my best.no headlight.Have brake light when i apply brakes but no running light.the front round yellow turn signals stay on but the rear ones dont.All turn signals work and the alarm works,when i use the control for right and left.The signal light works on the stearing box but the beam one dont.does this help any more
  • 1977 CB550F2
Re: wiring 550 1975
« Reply #3 on: June 17, 2012, 08:04:41 AM »
I would check your fuses again by replacing them with known working ones. They may look fine but can be burnt out in a hard to see way.
jontc
Re: wiring 550 1975
« Reply #4 on: June 17, 2012, 12:49:14 PM »
Now only have horn.Everything else is gone.I must of unplugged something in the headlightbucket.In the good news got the front end together and will start on the front brake this week while still trying to get the wiring fixed.Will put up some pictures of some wires that maybe somebody can point me in the right direction
  • 1977 CB550F2
Re: wiring 550 1975
« Reply #5 on: June 18, 2012, 12:42:26 AM »
You found a problem. Clean that down to bear metal to make a good contact. Also do the ground at the right rear engine mount.
