Author Topic: Honda CB400F crankshaft endplay  (Read 1542 times)
Offline everm1nd
« on: June 17, 2012, 02:17:43 pm »
I noticed some knocking in bottom of engine and decided to disassemble it for revision. There is lengthwise crankshaft endplay about 1 or ever 2 millimeters. I don't find something about it in manual. In other (new) CB we don't find any endplay at all. Crankshaft fits perfectly. I don't understand where it comes from, because there is almost no any wearout. Seems like crankshaft endplay is a reason of knocking. Have you any ideas how I can fix it?
Offline camelman
  • Man... Myth... Legend
Re: Honda CB400F crankshaft endplay
« Reply #1 on: June 17, 2012, 09:35:13 pm »
Please describe your question better. Is the endplay at the end of the connecting rod to the piston, or elsewhere?  There should be a little play at the connecting rod on the crankshaft. I don't know the exact amount, but maybe 0.5 mm play sliding forward and backward along the crankshaft. There should be no play when you push or pull on the connecting rod.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline everm1nd
« Reply #2 on: June 18, 2012, 04:44:15 pm »
When I pull crankshaft from left to right holding at clutch there is some play. About 1 or 2 milimeters.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: June 18, 2012, 05:25:52 pm »
But your clutch isn't on the end of your crankshaft.
Offline camelman
« Reply #4 on: June 18, 2012, 05:31:22 pm »
I think we need pictures to understand your question.
Offline everm1nd
« Reply #5 on: June 19, 2012, 03:53:35 am »
Oh, that's not clutch, year! Sorry, I don't know how it names in english.
I made a short video. There is no link coz i can't insert it. Just copy and paste it in your address line:
youtu.be/0Pv_uLES6DI
  • 1977 CB550F2
« Reply #6 on: June 19, 2012, 04:04:00 am »
I'm no expert at this but have you tried putting the top crankcase on and see if it does the same?
Offline yesteryear
  • Long Live Rock n Roll
« Reply #7 on: June 19, 2012, 05:39:52 am »
Hi.
My 750 did that don't remember how much but when you re install the top case, cylinders,alternator and points seal mine did not do that any more.Done over 300 miles now no problems.Like I say mines OK don't know about yours.
Hope this helps
Offline everm1nd
« Reply #8 on: June 19, 2012, 06:14:49 am »
As I remember, there was some play with top cover, but may be it played less. I'm going to assemble it tomorrow, hoping that play will go away.
Offline yesteryear
« Reply #9 on: June 19, 2012, 07:37:46 am »
Forgot to mention I did fit new Honda main bearing shells.
Regards
Offline everm1nd
« Reply #10 on: June 19, 2012, 08:45:12 am »
Thanks for advice, but I'm going to change bearings this winter. I also have some troubles in cylinders head, so this will be big job.
