Author Topic: A little paint experiment.  (Read 12425 times)
Offline LesterPiglet
  • 1977 CB550F2
Re: A little paint experiment.
« Reply #25 on: June 19, 2012, 02:06:56 PM »
Thanks ekpent, I'll look him up.
You have all the good bikes, we need some here. Even a few s**te ones for spares would be welcome.
  • 1977 CB550F2
« Reply #26 on: June 19, 2012, 02:14:11 PM »
The method I'm using could become expensive and time consuming. If you try to rub down between coats the flake loses colour so you need to put lashings and lashings of clearcoat on instead of rubbing down.
« Last Edit: June 19, 2012, 03:41:56 PM by LesterPiglet »
Offline 701arvn
« Reply #27 on: June 19, 2012, 03:30:30 PM »
  • 1977 CB550F2
« Reply #28 on: June 19, 2012, 03:42:40 PM »
Lester,
this might help:
http://forums.sohc4.net/index.php?topic=56529.0
Andy
Thanks Andy, I need all the help I can get. :)
Offline 701arvn
« Reply #29 on: June 19, 2012, 03:48:29 PM »
Holo FLake Wheelie Bin - Love it ;)
Offline Lostboy Steve
« Reply #30 on: June 20, 2012, 08:58:14 AM »
Did you just mist over that red? I want to do my brothers bike jet black and then mist some sapphire blue flake over it. Btu I want it subtle so its still got a lot of black showing through.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
  • 1977 CB550F2
« Reply #31 on: June 20, 2012, 09:32:59 AM »
Flake mixed with clearcoat. Not misted but a proper coat. It leaves it rough so you can't rub it down without the flake losing some colour.
You would need to put a lot of coats of clear on it before it became smooth. Check out the car, it looks a lot better. I sprayed very little on that so you wouldn't need as much clearcoat over it.
Offline Geeto67
  • A grumpy
« Reply #32 on: June 20, 2012, 01:21:03 PM »
There is a Subaru WRX STI color that uses the same effect. Flake is in the base coat but because it is black and a microflake it only shows up in direct sunlight as a glow. They changed the effect every year, 2005 I think it was gold, 2006 I think was red, not sure what year the blue was.
Don't bother with flake in the clear if you want it to be subtle. It will always be visible.
Maintenance Matters Most
Offline Mcwilliams570
« Reply #33 on: June 20, 2012, 01:30:49 PM »
Thanks for posting this Lester I have actually learned alot and thanks to Geeto67 for your insight and bothering to type and explain it some very good information..
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
  • 1977 CB550F2
« Reply #34 on: June 20, 2012, 02:29:55 PM »
No problems. Sometimes you need to post wrong stuff to get the gurus to chime in.  :P
Offline Geeto67
  • A grumpy
« Reply #35 on: June 20, 2012, 06:21:50 PM »
I am no guru.....I started out airbrushing model cars and then had a job as a sign painter (before I went back to school). I still use my airbrush for small jobs but I have never done anything larger than a motorcycle tank (unless you count long rectangular signs). Working with an airbrush you learn to use a lot of effects, but I am still #$%*e with a larger gun.
The best advice I can give you is the best paint job starts with good prep and good post.
