Good morning everyone.
To be honest this quote pissed me off.
So late in the evening I went through each wire, checking, re-checking and checking once more.
I noticed one thing, on a couple of the wires, tiny teeth marks.
In the main wiring harness was a chewed wire, a green/ground wire that
grounded the rectifier,regulator, and field coil.
So all my readings were correct and now it is charging as it should.
Actually that quote was a good thing.
Forced me to slow down and check again.
It's not a mystery. It's a lack of investigation/test prowess.
