Author Topic: Oil leak  (Read 1996 times)
Offline salukispeed
Oil leak
« on: June 19, 2012, 09:48:39 AM »
Could use some help from the engine gurus.
 I am changing the outer countershaft seal on my 77 A and noticed the inner seal is not tight in the engine case. I can touch it with my finger and it can be turned in the bore easily. It seems odd that it is free to turn. Is it retained and kept from turning by the fit and press of the outer seal. I presumed it was held in place like the bearing and when the cases were assembled it was a tight fit. I know it can not be replaced with out splitting the cases. I can't have oil leaks on my Honda's.
Thanks
1974 CB750 K4
1970 CT70
1966 CA77 (305 Dream)
1984 GL1200 Interstate
1977 750A
1972 CL100
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Oil leak
« Reply #1 on: June 20, 2012, 09:25:02 AM »
FYI - I forwarded your question to Bill Benton who has cracked open these cases more than once.
It doesn't appear (to me) that the inner seal does much - it almost looks like a slinger to me, but I've never been inside the case of a CB750A, so I'm hoping that Bill will share his knowledge on this one.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline salukispeed
Re: Oil leak
« Reply #2 on: June 20, 2012, 12:03:13 PM »
Thanks for the help. I only want to do this once if possible.
1974 CB750 K4
1970 CT70
1977 750A
1972 CL100
Offline salukispeed
Re: Oil leak
« Reply #3 on: June 26, 2012, 09:51:42 AM »
I did get the new factory honda seal and got it pushed in place until it solidly contaced the inner seal . I rode it a few miles last night and it looks like I have gotten rid of the leak, Will have to see if it stays that way. I ordered another seal just in case. Thanks for the help.
1974 CB750 K4
1970 CT70
1977 750A
1972 CL100
