Author Topic: Is this throttle return spring safe?  (Read 5759 times)
Offline karateisland
« on: June 20, 2012, 06:22:39 PM »
The original owner seems to have removed and/or lost the throttle return spring and used some sort of light spring home remedy for his carbs.
Before I get this cb350f going, I'm going to need a new spring, but this is the only one I can seem to find! Is it safe?
http://www.ebay.com/itm/THROTTLE-LINKAGE-RETURN-SPRING-1973-73-HONDA-CB350F-CB350-FOUR-CB-350-350F-/160768566257?pt=Motorcycles_Parts_Accessories&hash=item256e8da3f1&vxp=mtr#ht_1848wt_1093
72' CB350f (The Red Baron)
Offline Dimitri13
  • 1974 CB550K
Re: Is this throttle return spring safe?
« Reply #1 on: June 20, 2012, 06:26:29 PM »
Might be a little stiff. Just go to a hardware store and get a spring of the proper length, should cost less than $2 for one.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: June 20, 2012, 06:40:36 PM »
Please oh PLEASE don't spend that much money on a spring for your carbs..
Post in the parts wanted section if you haven't already.  That price for that part is pretty ridiculous, aside from it's obvious corrosion.
« Reply #3 on: June 20, 2012, 06:48:12 PM »
Posted. Patience is difficult when the bike is waiting to be ridden!
Hinomaru
« Reply #4 on: June 20, 2012, 07:03:39 PM »
Your 350F throttle return spring is part number:16036-323-004 and shows no longer available from Honda. :(
However, the part number cross reference list shows that same spring part number was used on the following models listed below.
Disclaimer: The cross reference list is usually 99% accurate, but I have found discrepancies in the past.
CB350F A MOTORCYCLE, JPN, VIN# CB350F-1000001
CB350F1 A MOTORCYCLE, JPN, VIN# CB350F-2000001
CB400F A MOTORCYCLE, JPN, VIN# CB400F-1000006
CB400F A (76) MOTORCYCLE, JPN, VIN# CB400F-2000001
CB400F A (77) MOTORCYCLE, JPN, VIN# CB400F-2100001
CB500 A MOTORCYCLE, JPN, VIN# CB500-1000001
CB500K1 A MOTORCYCLE, JPN, VIN# CB500-2000001
CB500K2 A MOTORCYCLE, JPN, VIN# CB500-2100001
CB550 A MOTORCYCLE, JPN, VIN# CB550K-1000001
CB550F A MOTORCYCLE, JPN, VIN# CB550F-1109886
CB550F A (76) MOTORCYCLE, JPN, VIN# CB550F-2000003
CB550F A (77) MOTORCYCLE, JPN, VIN# CB550F-2100001
CB550K A (76) MOTORCYCLE, JPN, VIN# CB550K-1230001
CB550K1 A MOTORCYCLE, JPN, VIN# CB550K-1200001
Offline xsmooth69x
« Reply #5 on: June 20, 2012, 09:22:27 PM »
dude for that price ill do it $10 cheaper and pull one from the junk yard that is way way way cleaner than that!
crazy how someone can post such a price!
1975 CB550 (FINISHED?!?!?)
Offline lucky
« Reply #6 on: June 20, 2012, 09:30:30 PM »
I would have washed that part and sprayed it with WD40 before even overing it for sale!
Offline xsmooth69x
« Reply #7 on: June 20, 2012, 09:45:42 PM »
i mean the spring even looks F'ed up
« Reply #8 on: June 20, 2012, 10:29:50 PM »
thirty six bucks?????????go to a nut and bolt or engineering supply place,take loose change with you.
« Reply #9 on: June 20, 2012, 10:39:21 PM »
That should make it worth $37...
« Reply #10 on: June 20, 2012, 10:58:37 PM »
it must come with carbs attatched?
« Reply #11 on: June 20, 2012, 11:05:47 PM »
Not just carbs; carbs custom tuned by Lucky! ::)
« Reply #12 on: June 20, 2012, 11:14:10 PM »
if your spring is light to pull but still returns the slides positively itll be ok so long as the hook part is secure over the ferrules and the spring isnt being over stretched,the genuine ones are very strong,,too strong.
« Reply #13 on: June 20, 2012, 11:23:18 PM »
And with a properly adjusted push-pull two cable setup, a strong return spring is not needed.
« Reply #14 on: June 21, 2012, 12:02:20 AM »
+1, i always use lighter springs....
bollingball
« Reply #15 on: June 21, 2012, 01:26:38 AM »
Hey if you are willing to pay that much.
I got a bike I will sell you for the same mark up price ( 5000%) with a spring on it.
 :o :o :o :o
Offline tomkimberly
« Reply #17 on: June 21, 2012, 02:27:25 AM »
its missing the spring.
Offline tomkimberly
« Reply #18 on: June 21, 2012, 03:09:46 AM »
You can tell that from the picture????  Looks like it's there to me.
Tom
bollingball
« Reply #19 on: June 21, 2012, 08:56:50 AM »
Maybe Dave left this off  ;D ;D ;D ;D ;D ;D
Ken
Offline Really?
« Reply #20 on: June 21, 2012, 09:01:25 AM »
Hell, I have two springs on mine.  It came that way so I left it.  Works fine.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline xsmooth69x
« Reply #21 on: June 21, 2012, 09:03:42 AM »
i hope he didnt actually buy it, if you want a spring ill do it for $15 shipped with an incredibly clean spring! ill even soda blast and wd40 the thing!
« Reply #22 on: June 21, 2012, 11:34:20 AM »
Did not buy it. If you have one, I'd be happy to take it off your hands! (You wouldn't happen to have some cb350f handlebars and mirrors, too?)  :P
« Reply #23 on: June 21, 2012, 12:11:26 PM »
Ken
you can clearly see the spring,i shouldve used smiley faces!
Offline tomkimberly
« Reply #24 on: June 21, 2012, 01:41:41 PM »
LOL!
