Author Topic: Push/Pull throttle  (Read 1226 times)
Offline faux fiddy
  • bike in a box
Push/Pull throttle
« on: June 21, 2012, 03:31:11 AM »
Anyone ever swap cables, are the push and pull basicly the same on the 350f (and any other SOHC if you know)?
Anyone swapped them on Anything?
Just wanting to  trim the flea bay  budget and  use what I have, which is two of the pull cables from a 350f.
Thanks for comments.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline LesterPiglet
  • 1977 CB550F2
Re: Push/Pull throttle
« Reply #1 on: June 21, 2012, 03:50:12 AM »
On the 550 they are both different. The push cannot do the job of the pull.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #2 on: June 21, 2012, 05:31:21 AM »
Same on the 750. There is NO adjustment on the push cable. (up by the lever)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline lucky
« Reply #3 on: June 21, 2012, 06:40:47 AM »
The so called "push" cable has a larger diameter barrel on the throttle end of the cable. They will not interchange.
The designers made it that way so there would be no mix up and cause a person to hook them up incorrectly and cause a person to have an accident by assembling the cables backwards.
Offline faux fiddy
  • bike in a box
« Reply #4 on: June 21, 2012, 07:12:10 AM »
I assumed I would have to buy something, but had hoped not.
Now another .... the one that sits forward of the pair is the pull?
Offline bjatwood
  • 1973 CB750-K3
« Reply #5 on: June 22, 2012, 07:42:26 AM »
Yep
Brian
#24193
