Author Topic: CB550F build - need help jetting CR29 carbs  (Read 2508 times)
Offline akabek
« on: June 21, 2012, 09:12:10 AM »
Hi Folks, hello to everyone as this is my first post on this forum.
I purchased a 1975 CB550F last fall that has been converted to a cafe.  I just need to tweak a few things but my last challenge is jetting the carbs.  The is some insight into my current setup.
Stock engine
Dyna electronic ignition, 5 ohm coils and wires
Keihin CR 29 carbs
4-2 Jardin exhaust
D7EA spark plugs
Steel dragon velocity stacks with aluminum screens
Can someone provide me with base line jetting for this setup?  No matter what I do I get good low and high throttle response but the mid range is lagging and when I pull the plugs it seems to running rich.  Maybe the CR29 that came with the bike is too much carb for a stock engine.  This bike is for street riding.
I appreciate any help.
« Last Edit: June 21, 2012, 01:20:19 PM by akabek »
Offline akabek
Re: CB550F build - need help jetting CR29 carbs
« Reply #1 on: June 21, 2012, 11:42:00 AM »
I emailed Keihin/Sudco asking for their baseline and this was their response:
120 mains, 70 pilots, YY5 in the 4 position, 2.5 slide, and 170main air jet.
I have no idea what the 2.5 slide means.
This is what I am currently running and the plugs are black when I pull them  100 mains, 48 pilots, YY8 in the top clip position - lean, and 240 main air jets.  Maybe I am not using the correct process to check the plugs.
The jets  and needles suggested by Sudco seem rich.
I also asked the base line for the same bike setup but a 4-1 exhaust....apparently they suggest the same base line.  I find that hard to believe.
« Last Edit: June 21, 2012, 01:21:41 PM by akabek »
Offline akabek
« Reply #2 on: July 22, 2012, 04:22:36 PM »
I did not get any responses to this thread but I thought I would provide an update.  I ended up with 65 slow, 120 mains, 5th position on the needle and 1.5 turn on the mixture screw and the bike now has steady acceleration throughout each gear.  I do need to do some plug chops to see how the plugs are at idle, 1/4, 1/2, 3/4 and open position.
