Author Topic: Came across 1974 cb 750 that is near mint, sitting 30 yrs  (Read 32198 times)
Offline Johnie
Re: Came across 1974 cb 750 that is near mint, sitting 30 yrs
« Reply #100 on: June 24, 2012, 03:02:54 PM »
As long as one of those numbers match the title you are good.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Trevdawg
« Reply #101 on: June 24, 2012, 09:53:28 PM »
I think I should change the title of this thread to "came across a 1974 cb 750 in decent shape, sat for 30yrs"
Didn't get plugs today or anything. Was busy. But will get them tomorrow while at work. My job is by a parts shop. hope to have running Atleast in the next couple days, then will work on front brake.
The oil was a rustic color. I will upload that pick later.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #102 on: June 25, 2012, 08:50:39 AM »
Nice find! With a bit of work that will be a true 750 survivor for sure  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Bankerdanny
  • Endeavor to persevere
« Reply #103 on: June 25, 2012, 09:49:06 AM »
On an Illinois title the only number that appears should be the one on the frame.
Offline Johnie
« Reply #104 on: June 25, 2012, 11:19:31 AM »
Interesting...in WI the only number on the title of these older bikes is the engine number.
Oshkosh, WI  USA
« Reply #105 on: June 25, 2012, 04:29:49 PM »
WI is the only state I've heard of that did that.
Offline BeSeeingYou
« Reply #106 on: June 25, 2012, 04:41:31 PM »
Minnesota does it off the engine number too.
« Reply #107 on: June 25, 2012, 04:59:49 PM »
I stand corrected.  The K2 I bought from NY had no title but I can use the transferable registration to get a TX title. (NY did not issue titles to bikes back then)
Offline Tews19
  • I am no
« Reply #108 on: June 25, 2012, 05:05:47 PM »
With my 550F, the original title was issued using the engine. When I got the title for the 1971 750 re-issued through the hassle process  I purposely requested title using the frame VIN. DMV obliged.
« Last Edit: June 25, 2012, 06:37:48 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Trevdawg
« Reply #109 on: June 25, 2012, 06:26:29 PM »
I hate to ask but it is to hard to look this up on my phone on this sight.
I bought NGK - D8EA plugs.... What should the gap be?
I'm about to put these in..
Offline Trevdawg
« Reply #110 on: June 25, 2012, 06:45:44 PM »
Found it .025-.028
Offline Trevdawg
« Reply #111 on: June 25, 2012, 11:07:24 PM »
Tried to change oil filter . . . no luck
maybe after we get it running, the heat and movement of the oil will help loosen the bolt. Its almost stripped. Then we cut the center of it to put a flat head in there, and no luck.
tank is empty and put stuff in it to get rid of the light rust, and saw this!!!
I saw this while under the bike. I have no idea what it can be from.
Lastly, How important is this secondary cable?
Offline fastbroshi
  • Puppet
« Reply #112 on: June 26, 2012, 02:33:48 AM »
Hino, what table is that?  I had a chance to use one just like that to service the rear end bearings on my VFR and it was a joy not to have to sit on the ground to work on it.
Just call me Timmaaaaay!!!
Offline Scott S
« Reply #113 on: June 26, 2012, 04:11:51 AM »
 Do you have an impact gun/wrench? I have an electric one in the garage and it makes short work of stuck nuts and bolts that I would have mangled using other methods.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Johnie
« Reply #114 on: June 26, 2012, 05:46:05 AM »
Yah, that oil filter bolt is a constant issue here which is why I warned you about it a few posts up. There are ways to get that off you can find on the search function. Two that come to mind is to weld another bolt on the bad one. The other thing guys do is take a power hack and cut the bolt off, but you will need to get a new oil filter housing once you do that one.
With the way the petcock looks with all that gel in there I would soak it in carb cleaner and be sure you change those fuel lines. You can get a replacement petcock screen from Honda or just try to clean it out with carb cleaner.
The double throttle cable system is a nice feature and not sure why you want to remove it. The push / pull cable system is designed to allow the driver to pull the throttle back in case it gets stuck open which would not be good. No benefits to remove it.
That little  bit of oil on the bottom of the motor is the least of your problems. Don't worry about it. Good luck with the bike and let us know how it comes out.
« Last Edit: June 26, 2012, 05:49:45 AM by Johnie »
Oshkosh, WI  USA
« Reply #115 on: June 26, 2012, 05:54:26 AM »
It looks like your B cable is broken?
In a perfect world you should have it. To answer your question, it is not necessary. Just be sure your throttle snaps back to idle. Which it should do whether you have the B cable hooked up or not.
As to the oil filter bolt, this is one of those things that age creates. The bolt is not stuck because it is too tight. it is stuck because a chemical reaction has occurred between the bottom of the flange of the bolt and the filter housing. From exposure to the elements, condensation and road spray. had it been removed once a season, it would not be stuck. If you can grind or drill the flanged part of the bolt off without getting into the housing, you will spare the housing. Once the flange part is off, the housing will pull off and you'll have the length of the bolt to work with. But you'll probably be able to turn it out by hand.
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #116 on: June 26, 2012, 06:56:29 AM »
Trevdawg- Don't let these issues get you down.  We've all been there (and will be there again).  Someone above said "take your time" and they're right.  The outcome will be worth it on many levels.  Remember, you have a lot of guys here cheering you on.  Good pics BTW!
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline Trevdawg
« Reply #117 on: June 26, 2012, 07:06:05 AM »
I like the idea to weld another bolt to it. We will have to try that.
Johnie I don't want to remove anything. I just noticed the cable was snapped and was curious how important that part is. The throttle operates smoothly even with one cable. I'm going to try and find that part B throttle cable part #.
We put that evapo rust in the tank so I can't wait to see it today.
We cleaned out the pet cock screen pretty good. But the bowl/ housing had 2 pinholes in it. My friend is a welder so he said he has something at work to patch them. Didn't take a pic of it.
Offline Tews19
  • I am no
« Reply #118 on: June 26, 2012, 07:08:30 AM »
Order a new cable from motion pro. They can have you a new one by friday or call your local motorcycle shop... May have one on hand. Cost maybe 20 bucks tops.
AS others have said, these are minor bumps in the road. That bike is way to nice to worry bout minor details for now. Once you get her running and enjoy her then go forward with making her mint.
If you need a petcock I have an extra laying around in my basement. In MIlwaukee so I am near by. Let me know.
I even have a used OEM cable if you need it.
Offline Trevdawg
« Reply #119 on: June 26, 2012, 07:11:03 AM »
Thanks chuck. In just egear and excited. But I understand that it takes time and patience.
I'm leaving for FL on Friday and aiming to have it Atleast start.... By Friday. That doesn't mean run but ...
I also got a new battery. It is interesting putting the acid in the battery.
Offline Trevdawg
« Reply #120 on: June 26, 2012, 07:19:56 AM »
Tews motion pro is a good sight thanks.
Is the broken cabl the push or pull one though?
I'm gunna order once I know. Or what's the difference between the 2, length?
« Reply #121 on: June 26, 2012, 07:23:24 AM »
Its the B cable. Known as the push cable, but it doesn't push anything. (pet peeve of mine)
The B cable doesn't have an adjuster on it. Probably length is dif too.
« Reply #122 on: June 26, 2012, 07:34:40 AM »
There have been complaints of the Motion Pro cables, personally I would spend the extra few bucks and buy the Honda cable.
And would not be a bad idea to change both.
Offline Johnie
« Reply #123 on: June 26, 2012, 08:18:01 AM »
I have to agree with Steveo here...I have heard about problems with the Motion Pro cables too. You would be better off OEM or get the used one from Tews.
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #124 on: June 26, 2012, 08:23:56 AM »
I agree  stev-o and johnie as well about motion pro. I am not sure of his motivation or funds for the bike.  Motion pro for my 750 at the moment are Ehh status. I may have to look into new oem ones too.
