Author Topic: Honda 400/4 cam R6???? Maker?  (Read 1815 times)
Offline Chris Tyler
« on: June 23, 2012, 12:23:48 pm »
Hi
Just had a peek at the engine I brought. The cam is marked R6.
No other markings.
Any ideas?
Bike runs well,  to about 9000 revs. When you change down it has engine braking but if the revs drop below 5500 it bogs a bit & takes a while to pick up. Between 7 & 9 it picks up & fly's. Through the gears it revs out to 9 in each gear, really well. Found I need to run it like a 2 stroke, change down, dump the clutch & keep it around 6 & a bit & it picks up fine. Lots of grin factor. ;D
Thanks
all the best Chris
« Last Edit: June 24, 2012, 03:48:11 am by Chris Tyler »
Offline RickB
    • Pop Magazine
Re: Honda 400/4 cam
« Reply #1 on: June 23, 2012, 12:38:08 pm »
That's exactly how I feel I have to ride my mostly stock CB400F. I've got a NOS cam in it too so I'd be interested to know what the R6 means. I'm running rebuilt stock carbs, stock headers with an after market pea shooter muffler.
I hate that bogging at lower RPM, without it I just know I could beat my mates BMW r75/7 in a drag race!
Offline Chris Tyler
Re: Honda 400/4 cam R6???? Maker?
« Reply #2 on: June 25, 2012, 12:41:52 pm »
Hi
Been contacted by another racer whose cam is marked R1?
He also has know idea who made it.
Chris
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #3 on: June 25, 2012, 03:05:05 pm »
In all likelihood unless there are other identifying marks say on the end etc what you have is a HONDA cam. Those markings mean nothing to us. This is old conversation that goes way back.
Offline Tim2005
« Reply #4 on: June 25, 2012, 03:09:48 pm »
I agree, R6/R5 etc don't mean anything. Power 7-9k indicates a stock cam too, however the simplest other check is to measure the lobes - a good rule of thumb is that if they are under 29mm across then it is probably a stock cam ( they tend to be around 28.5mm but they do vary, they even vary from lobe to lobe too).
Offline Chris Tyler
« Reply #5 on: June 27, 2012, 12:35:22 am »
Hi
Thanks for the reply's so far.
I dont intend stripping the engine down this season. Too inclined to rebuild it completely, if I did.
Could well be a stock cam, daft as I could have measured it quite easily! ::)
Hopefully I can get it out for another run soon.
all the best Chris
