Author Topic: CB750 Speedometer Drive - Double Disc  (Read 3131 times)
Offline spiritof67
« on: June 26, 2012, 07:38:16 pm »
Do any of our erstwhile contributors have available precut stock Honda speeedometer drive "discs" to be used in the double disc conversion? Like the ones CFC/Yoshimura used to sell?
Spirit
Online scottly
Re: CB750 Speedometer Drive - Double Disc
« Reply #1 on: June 26, 2012, 07:48:45 pm »
What year 750? There were 2 different drives.
Offline H2Eric
« Reply #2 on: June 27, 2012, 09:01:58 am »
Chappie with the username 'rangelov' on here did some a while back. Not sure if he is still in business, but might be worth a search. Failing that they don't look too difficult to have made, might be worth having a chat with a friendly machinist regards cost etc. and have a small batch produced.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline Tintop
« Reply #3 on: June 27, 2012, 03:14:05 pm »
bwaller showed how you can make the 'tab'd' drive plate from the newer one.
http://forums.sohc4.net/index.php?topic=70195.0
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline spiritof67
« Reply #4 on: June 28, 2012, 09:38:18 am »
It's a 1974 K4.....
Spirit
« Reply #5 on: June 28, 2012, 10:24:09 am »
It's a 1974 K4.....
Spirit
I made my first one from the stock drive. Ground down the OD with a bench grinder. Left enough material strategically placed to bend over with a vice to make the drive tabs. Not pretty but functional. I'm looking for a pic.
Currently i had one made at a machine shop for $20. Instead of a bench grinder they used the mill. Then welded 2 strips for drive tabs. Very pretty.
Rangelovs was the best I've seen though.
Offline spiritof67
« Reply #7 on: June 28, 2012, 09:28:41 pm »
Hey, Rangelov, still got any left?
Spirit
Online scottly
« Reply #8 on: June 29, 2012, 06:39:07 pm »
Just read through your other thread on the tech forum; are you looking for a drive to fit a Com-star wheel?? Rangelov's adapters are for the early 750s with the two flats on the hub.
Offline spiritof67
« Reply #9 on: June 30, 2012, 04:02:25 pm »
Scottly, yes, I have the two-flats hub on my K4 and I already have one Rangelov drive. It's a piece of real art. Hope he's out there listening - and has a few left. PS: With his drive, if you use standard Honda hubs (and polish them..) the Rangelov adds just that extra bit of brightness..
Spirit
Offline fang
    • Food Renegade
« Reply #10 on: July 06, 2012, 01:48:55 pm »
Spirit, here's what I ended up doing.  I am not sure if it would be a good fit you you or not, but it has a working speedo, AND used the lighter 550 rotors.
http://forums.sohc4.net/index.php?topic=66844.0
Plus it works very well.
-Fang
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
Offline spiritof67
« Reply #11 on: July 06, 2012, 05:03:07 pm »
Nah, I just wanna wake Rangelov up!
I appreciate all the folks that want to do the "physics correct" thing and have the calipers behind the fork legs. But I like the "CB750" esthetic of having them where they originally were. I'm going to use Kimtabs anyway, so I've already lowered the rotating mass..and I'll have drilled, thinned discs as well.
Nah, for me I need another Rangelovdrive. R Man, where are you?
Spirit
Offline H2Eric
« Reply #12 on: July 07, 2012, 08:22:48 am »
I've sent rangelov a PM, but got no reply. Guess I'm going to have to try and get a similar item made. I know a man who can make one, it's just a matter of time.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
