Okay, I probably should have mentioned I'm new to this, sorry for not including enough info.
My bike is a 1972 CB500
Main jet is 100 ( just replaced )
Idle jet is 40 ( my manual says that is stock )
Slide needle clip position is 2nd from the top, not 4th ( I'm assuming the slide needle is the same as the jet needle.)
Mixture screws are set to 1 turn out. I read to start there, so that was my plan.
Float height is 22mm
Exhaust is 4 into 2.
Intake? Not sure how to answer this one.
My carbs are not back on the bike yet, and my question was asking for a recommendation on needle jet clip height considering the 4 into 2 exhaust.
I've replaced all the jets, and the jet needle, as well as the adjuster screw basically doing a full rebuild on the carbs. I've pulled and thoroughly cleaned my emulsion tubes. Essentially I'm ready to put it all back together and was just hoping for some insight as to a recommended change, if needed, for my jet needle clip position.
