Author Topic: '72 cb750 engine into a '78 cb750 frame  (Read 1156 times)
Offline junkyhands
    • flickr
« on: June 27, 2012, 02:23:13 PM »
I've got a '72 cb750, but the frame is unregistered.  i have a lead on a '78 cb750 frame with papers (sohc) and i was wondering if the '72 engine would swap straight in or if I'd need to modify it.  Any thoughts?
Thanks so much!
Offline brandEn
Re: '72 cb750 engine into a '78 cb750 frame
« Reply #1 on: June 27, 2012, 04:17:58 PM »
Is it a 78 K or F ?
The engine will mount right in no problem. But just so you know the 78 used a 630 chain and different carbs so take that into account. Those could be an issue that needs to be worked out.
Offline junkyhands
    • flickr
« Reply #2 on: June 27, 2012, 05:48:35 PM »
It's a K model.  I have a fully running '72 K so i can swap the rear wheel and engine onto the '78 frame.  I wouldn't have a problem then, would I?
Thanks for the reply!
Offline Patrick
« Reply #3 on: June 27, 2012, 06:16:46 PM »
The engine will go into the frame fine, but you will need other parts to make it work. If both bikes are complete, no problem. For the k2 engine, you will also need the k2 sprocket carrier. To go into the '78 frame you will need the '78 axle and spacer.
There are certainly other things I am not remembering right now.
But with two complete bikes, no problem. I did exactly that - a K2 engine in an F3 frame - on my last 750.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline junkyhands
    • flickr
« Reply #4 on: June 27, 2012, 08:16:20 PM »
Cool!  Thanks, guys!
I'm excited to wrench.
Offline GammaFlat
« Reply #5 on: June 28, 2012, 07:28:26 PM »
Without thinking about it too much, maybe you could run the 72 swing arm on the 78 frame and all alignment would be good.  This way, you could use all the 72 parts on the swing arm (wheel, spacers, sprocket, etc.).  The key is whether the relationship between the swing arm location and engine is the same between the pre-K7 and post K6.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
