Author Topic: F2 rod bolts  (Read 4791 times)
Offline Big Jay
    • CBRzone
F2 rod bolts
« on: June 30, 2012, 05:58:17 PM »
Are they a direct replacement into earlier K rods? Never have been a big fan of trying to use the stock rods in built Honda motors, so we have never tried this before.
I remember back in the day when RC put the small block Ford bolts in them.
Re: F2 rod bolts
« Reply #1 on: June 30, 2012, 08:43:05 PM »
I wonder if ARP has a small block ford bolt that would work? Hmmm, surely the rod would meed machining.
 I have read about the F bolts being used but haven't done it myself.
« Last Edit: June 30, 2012, 08:44:46 PM by Don R »
Re: F2 rod bolts
« Reply #2 on: June 30, 2012, 08:56:57 PM »
As you probably know the "rod" is listed as a complete unit with the bolt and nut but the bolts and nuts are also listed separate. The part numbers for the rod, bolt and nut are -300 until engine number 2604929. From what I've heard the bolts and nuts changed but the rods were the same. I've also heard that Corvair bolts were used as hd replacements. Operative word here is "heard" with no true experience. The F2/F3 bolts ands nuts are still available so that would give a definitive answer.
Let's get a definitive from our motorhead experts.
« Last Edit: June 30, 2012, 08:59:37 PM by Jerry Rxman Griffin »
Offline brandEn
Re: F2 rod bolts
« Reply #3 on: June 30, 2012, 09:40:27 PM »
subscribed
Offline jaguar
Re: F2 rod bolts
« Reply #4 on: June 30, 2012, 09:51:12 PM »
Also in for information on HD rod bolts
Offline classic bike tuner
  • http://www.cmrch.nl/
    • cmrch.nl/
Re: F2 rod bolts
« Reply #5 on: July 01, 2012, 03:20:53 AM »
13213-kvo-000  bigend bolts  can use std nuts
direct replacement fits direct olso for the smaller engines  350-400-500-550-650
actually the are from a vtr 250 olso used in cbr 600 and a lot more
gerrit
Re: F2 rod bolts
« Reply #6 on: July 01, 2012, 06:35:35 AM »
Agreed they are a direct replacement. Nuts are 13214-410-003.
Offline voxonda
Re: F2 rod bolts
« Reply #7 on: July 01, 2012, 03:21:59 PM »
Yep, direct replacement.
Re: F2 rod bolts
« Reply #8 on: July 01, 2012, 03:59:06 PM »
They work on 550 rods as well
Offline jaguar
Re: F2 rod bolts
« Reply #9 on: July 01, 2012, 05:01:10 PM »
So the F2 bolts are stronger then the K bolts and are a direct swap.  Is there something that is stronger still that also bolts in, or is it not worth it?
Re: F2 rod bolts
« Reply #10 on: July 01, 2012, 06:00:39 PM »
Not that I know of.
Offline bear
  • Leeton in Australia
Re: F2 rod bolts
« Reply #11 on: July 02, 2012, 05:40:16 AM »
I know this is out of left field for the tech heads on this site.
But check out the pic attached.
Yes the conrod bolts are cat8.
I race with these blokes and they have been around for awhile.
I asked them why?
And they said they couldn't get the proper bolts at the time.
I do not lie, this motor actually managed to complete two meetings before it finally sh!t it self.
Brian
« Last Edit: July 02, 2012, 06:19:22 AM by bear »
Re: F2 rod bolts
« Reply #12 on: July 02, 2012, 05:55:28 AM »
Holy $hit! You guys must have the "really good" hardware stores! ;D
Offline mec
Re: F2 rod bolts
« Reply #13 on: July 02, 2012, 09:52:12 AM »
Brian
please give me their phonenumber, i need to have done some safety wiring :)
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Re: F2 rod bolts
« Reply #14 on: July 08, 2012, 08:51:44 PM »
That filter shouldn't tighten any more than it already is!
Offline Old Scrambler
Re: F2 rod bolts
« Reply #15 on: July 09, 2012, 12:35:46 PM »
Will there ever be a need for REPRODUCTION cases 8) 8) 8) 8) 8) 8) 8) 8)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline turboguzzi
Re: F2 rod bolts
« Reply #16 on: July 09, 2012, 03:31:14 PM »
initially i thought it was hilarious,
but coming to think about it, if you crash your brains out due to oil left by someone else using hardware store "con rod bolts" then thats not funny at all.
would heavily fine them or something, no kidding
TG
Offline solo 2
Re: F2 rod bolts
« Reply #17 on: July 09, 2012, 08:41:54 PM »
I posted this in my thread I think but here's the difference, the spiral groove probably does not help the strength of the K bolt.
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
