Author Topic: huge difference after cutting pug wires!  (Read 1980 times)
Offline lostmykeys
« on: July 01, 2012, 07:55:47 PM »
 Yesterday I wanted to re gap my plugs from 28 down to 24.Instead I just bought some new plugs even though the old ones had less than a thousand miles on them.The new plugs were already factory gapped at 24.
 While I was at it I unscrewed the plug wire caps and cut the wire back until I could see clean copper wire.One of the wires had to be cut back about a half inch before I could see clean copper.
 I thought the bike ran fine before this so I had no reason to try this.
 But I'm glad I did not only does the bike have more tourqe but it has less top end noise and the tranmission shifts smoother.
Re: huge difference after cutting pug wires!
« Reply #1 on: July 01, 2012, 08:02:20 PM »
May not be a bad idea to change the plug caps too, only a couple bucks each.
Offline DJ_AX
« Reply #2 on: July 01, 2012, 08:04:18 PM »
+1
Offline lostmykeys
« Reply #3 on: July 01, 2012, 08:07:41 PM »
 Thanks, where are you finding plug caps at that price? By the way these would be for a 78 f3
Offline DJ_AX
« Reply #4 on: July 01, 2012, 08:31:25 PM »
A couple bucks? Yeah where? Wish I knew... I paid about $12 each.
« Reply #5 on: July 01, 2012, 08:36:33 PM »
Z1 Enterprises, $2.24 - $3.01. Make sure you get the right type, the 550 uses two different ones.
http://www.z1enterprises.com/SearchResult.aspx?All=True&KeyWords=ngk%20cap
Offline lostmykeys
« Reply #6 on: July 01, 2012, 08:40:42 PM »
 Steve O, what kind of change can be expected after changing the caps?
Offline DJ_AX
« Reply #7 on: July 01, 2012, 08:51:51 PM »
You can easily test the resistance of your old caps... More than 10k ohms = bad :(
New caps come in at 5k ohms = good :)
Run a little better... plugs last longer... I'm sure someone else could elaborate further...  ::)
Offline lostmykeys
« Reply #8 on: July 01, 2012, 09:04:57 PM »
 How do you you check plug caps for resistance? I know you use an ohm meter, but what is the procedure?
Offline DJ_AX
« Reply #9 on: July 02, 2012, 06:09:15 AM »
You just take them off, and touch the tester leads to each side, and read the resistance on the meter. :) Quite simple actually.
« Reply #10 on: July 02, 2012, 06:41:48 AM »
Yes, simple. And less resistance equals better spark.
