Author Topic: Local source for CB750 oil filter?  (Read 8245 times)
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
« on: July 01, 2012, 10:29:46 PM »
I got a cross reference chart from CB750.org for filters like:
Fram# CH6009
Purolator# ML-16809
K&N# KN401
...but who locally carries those #'s?
CB750K6- survivor   CB500K2, CB550K2- projects
Re: Local source for CB750 oil filter?
« Reply #1 on: July 02, 2012, 04:12:10 AM »
Most auto shops have them...at least one of them. Advanced Auto carries the Fram.
« Reply #2 on: July 02, 2012, 05:28:42 AM »
Walmart should have the Fram one CH6009
bollingball
« Reply #3 on: July 02, 2012, 09:31:27 AM »
Yep WallMart has the fram Napa carries the wix.
  • SEE YOUR AD HERE!
« Reply #4 on: July 02, 2012, 04:17:05 PM »
That's what I thought but the Walmart I visited before posting didn't have that #.
  • SEE YOUR AD HERE!
« Reply #5 on: July 02, 2012, 04:21:33 PM »
I know they carry WIX there but must see if they have the wix#24940
  • SEE YOUR AD HERE!
« Reply #6 on: July 02, 2012, 04:26:15 PM »
I think I've seen the Fram one there only because I recognized the "naked" style it is.
Offline kpier883
  • is quite the
« Reply #7 on: July 02, 2012, 04:31:03 PM »
NAPA PS4940 is the NAPA re-badged wix 24940
« Last Edit: July 02, 2012, 05:17:44 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline Trevdawg
« Reply #8 on: July 02, 2012, 04:35:12 PM »
Very helpful
  • SEE YOUR AD HERE!
« Reply #9 on: July 02, 2012, 04:53:02 PM »
CB-750
Maker      Part No.
Honda     15410-426-010
EMGO      10-20300
Fram        CH6009
K&N          KN-401
Perf-form  OF-0047
Purolator  ML-16809
WIX          24940
Offline sir funk
  • 75 CB400F
« Reply #10 on: July 02, 2012, 04:57:26 PM »
CB-750
Maker      Part No.
Honda     15410-426-010
EMGO      10-20300
Fram        CH6009
K&N          KN-401
Perf-form  OF-0047
Purolator  ML-16809
WIX          24940
Advance Auto can Special order the K&N; comes next day.
« Reply #11 on: July 02, 2012, 11:59:36 PM »
Took me a while to find it in our walmart. They have a motorcycle section - it is not with car oils and filters.
Also Advance Autoparts have it on the shelf - in the small engine area.
But I always buy two to have a spare on the shelf, compare to car filters they are hard to find.
Offline cb650
« Reply #12 on: July 03, 2012, 12:05:37 AM »
I wish out wally world had a M/C section.    Most around here have been getting rid of the M/C filters.
Some orileys have been too.
  • SEE YOUR AD HERE!
« Reply #13 on: July 03, 2012, 06:05:23 PM »
thanks kpier883, good to know. I will add it to my list.
Offline Brantley
  • Drano
« Reply #14 on: July 04, 2012, 12:54:47 PM »
Just a heads up... I don't work for K&N, but I do use the KN-401. If you order from their site UPS ground shipping is free, conditionally: times past it was a dollar amount; right now looks like if you order 2 or more. And they are CHEAP right now!
bollingball
« Reply #15 on: July 04, 2012, 01:52:50 PM »
The Wix I have is 51390 the short one I need to look at the one you mentioned is it long or short. Maybe mine has been re-baged as well.
Ken
  • SEE YOUR AD HERE!
« Reply #16 on: July 05, 2012, 05:41:08 PM »
The Fram CH6009 I installed yesterday was so tight on the bolt (pre-oiled both) that the spring couldn't push it back. Had to really fiddle with it to install. Looks to be an original (correct) bolt. The "F" model (mine is "K") is a Fram CH6008, could I have the wrong bolt?
Offline cb650
« Reply #17 on: July 06, 2012, 04:50:25 AM »
Might be a old fram.    Many years ago they had problems with the center rubbers being to tight.  Havent encountered any in a long time.  Last one I just took back and showed the counter person the diff and did a exchange.
  • SEE YOUR AD HERE!
« Reply #18 on: July 06, 2012, 04:31:41 PM »
I'm thinking the spring & the ability of the filter to slide forward is the "bypass feature" (if the filter started to clog up) ??? and unless this one loosens from heat cycles, it isn't moving >:(
  • SEE YOUR AD HERE!
« Reply #19 on: July 07, 2012, 03:01:49 PM »
Ok, I read that the by-pass is in the bolt where I do see something.
I removed the filter assembly & the seals now slide somewhat easier than when first installed (after only 1 short heat cycle) so I think they're ok now, as they do need to seal on the bolt so all the oil goes through the filter.
I may need to start a new thread because I have lost track of how much oil is now in the bike :P
