Author Topic: 750 F to 750 K8 Header Compatability  (Read 1446 times)
Offline brewsky
« on: July 02, 2012, 08:23:21 AM »
Anyone know of any issues fitting an F stock header/collector on a K model.
Also any significant differences in the F model year headers?
TIA
« Last Edit: July 02, 2012, 09:01:51 AM by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline BeSeeingYou
Re: 750 F to 750 K Header Compatability
« Reply #1 on: July 02, 2012, 09:01:40 AM »
I have seen a few K bikes with the F 4 into 1.  Never done it myself but I know the brake pedal needs to be modified or changed or else the muffler hangs too low.  There is a thread or two about it if you do a search.
Offline brewsky
Re: 750 F to 750 K8 Header Compatability
« Reply #2 on: July 02, 2012, 09:06:39 AM »
The reason I ask is I'm considering using a reverse cone (Cycle X type), and thought it may fit better than with my existing MAC 4/1
header.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline BeSeeingYou
« Reply #3 on: July 02, 2012, 03:32:28 PM »
Here is a photo of the fit on a F1.  The brake pedal is different and I think the footpegs are also in a different spot than a K bike.  Whether the problem area is the collector or the muffler I am not sure but looks like the collector.
Offline brewsky
« Reply #4 on: July 03, 2012, 03:09:03 AM »
Thanks for the pic. srust......
I did a search but couldn't find anything specific that helped.
Maybe it's an optical illusion, but your collector appears to be square, (2 upper and 2 lower inlets) instead of 4 inline flat inlets?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline BeSeeingYou
« Reply #5 on: July 03, 2012, 02:06:02 PM »
The collector is more like an L on it's back,  three across inline and then the one up that makes it look square if viewed from that angle.  Saw this at bike night a while back.  A K bike in F clothes. ;D
Offline brewsky
« Reply #6 on: July 04, 2012, 03:27:43 AM »
Thanks for the pic.....that shows it can be done.....
The "L" shape isn't that obvious in the parts illustrations, but explains it well.
Appears to be a significant difference in design between the 75/76 and 77/78 years for some reason. The later year models appear to be more of a 4/2/1 affair instead of 4/1, and appears to be more "flat" than "L" shaped.
I remember reading somewhere that the stock F headers were pretty efficient, and thought they may breathe better than the MAC, but I'm unsure which design they were talking about.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
