Author Topic: Exhaust ???  (Read 1323 times)
Offline Mtmooradian
Exhaust ???
« on: July 02, 2012, 12:09:38 PM »
Can I put a cb750 header from an 80 on a 77?.... Modifications needed???
Re: Exhaust ???
« Reply #2 on: July 02, 2012, 12:50:33 PM »
 I think they do fit.. just make sure both motors are inclined the same angle..probably are...
Offline bjbuchanan
Re: Exhaust ???
« Reply #3 on: July 02, 2012, 05:05:13 PM »
I just put a whole exhaust from an 80 DOHC on to my 72 SOHC in a 76 frame
I made sure I got the clamps and half circle shim thingies. It's the same hardware I think used on your motor to mount the original header. New copper gaskets are a must. The port spacing is the same between the two engines
Offline bjbuchanan
Re: Exhaust ???
« Reply #4 on: July 02, 2012, 05:54:12 PM »
Here is what it looks like on my bike
Offline Mtmooradian
Exhaust ???
« Reply #5 on: July 02, 2012, 08:19:36 PM »
Sweet, I'm going to tie this pipe in
But it will be mounted parallel with the frame(chain stay)
Re: Exhaust ???
« Reply #6 on: July 02, 2012, 08:36:51 PM »
What swing arm is that?
Offline Mtmooradian
Exhaust ???
« Reply #7 on: July 02, 2012, 08:48:51 PM »
Check out my build.......it's a custom zx600 converted into a 3qt oil tank
