Author Topic: 75 550F carb:airbox rubber boots source?  (Read 3935 times)
Offline anteak
  • "No sign of life here, Jim." - Bones McCoy, 1966
« on: July 02, 2012, 06:37:13 PM »
Hey all. I'm trying to put an old supersport back on the road and a couple of the rubber boots between the carbs and the airbox are cracked or torn. I've tried to score some replacements with NO luck.
The exploded drawings and  fiche I've found online seem to show these as an integral part of the airbox or not at all. The drawings don't seem to be all that clear to begin with.
I don't want to switch to velocity stacks or individual air filters. Anybody out there able to offer be a source for these? Maybe repro stuff?
Thanks in advance for any help.
1983 BMW R80RT
2008 Kaw Versys 650
1975 CB550F0
Offline harisuluv
Re: 75 550F carb:airbox rubber boots source?
« Reply #1 on: July 03, 2012, 02:07:11 AM »
Those drawings are old but it should be pretty easy to find the part number. The airbox boots are much cheaper than the manifolds so oem is the way to go. Worse case scenario just call your local dealer and they will order them for you. It will be cheaper if you order them yourself online though.
« Reply #2 on: July 03, 2012, 02:22:36 AM »
Honda never sold those rubber boots separate from the air plenum assembly.
However, David Silver Spares sells them separately.
Offline anteak
« Reply #3 on: July 03, 2012, 05:30:42 PM »
Thanks a billion, guys. I'll get this bugger up and on the road yet.
 ;D
1983 BMW R80RT
2008 Kaw Versys 650
1975 CB550F0
Offline Scott S
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Zora
« Reply #5 on: July 04, 2012, 05:47:39 PM »
anteak - I'm in the same boat as you are. I'm looking for the same part for a '77 550F. I sent an email off to the guy at classicmotorcyclesolution.com and the parts are available.
'77 CB550F - Finally on the road...
'78 CB550K - not running yet...
'06 YZ450F
'01 KLX300
Offline anteak
« Reply #6 on: July 08, 2012, 10:40:56 AM »
Me, too. Bought & paid for. Shipping soon.
Thanks to all.
1983 BMW R80RT
2008 Kaw Versys 650
1975 CB550F0
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
« Reply #7 on: July 08, 2012, 11:19:39 AM »
well I bought 4 (@$10+ ea.) for my CB750K6 few years back from Honda ;)
CB750K6- survivor   CB500K2, CB550K2- projects
  • SEE YOUR AD HERE!
« Reply #8 on: July 08, 2012, 12:32:47 PM »
 ;D
Read the factory service bulletin on the 500-550 (pre '77) rocker cover. If caught early, an o-ring (4 total) in each rocker shaft's side cover has been reported to stiffel the steel shaft rocking & further shaft hole damage in the aluminum cover :) Unchecked, eventual valve train failure :'(
Offline singedebile
« Reply #9 on: July 08, 2012, 12:56:13 PM »
 ;D
Hmmm this sounds important, but i'm a little confused still about which O-rings your talking about
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
  • SEE YOUR AD HERE!
« Reply #10 on: July 08, 2012, 01:42:04 PM »
How many miles on your 550?
On both sides of the aluminum valve cover there is a polished small cover held by one phillips type screw. It's cast with 2 plugs to rocker shaft ends. The extra o-ring is squished in there to "bind" & stop shaft from rocking with the rocker arm. Usually the same size o-ring as the ones on the "plugs".
There is also an "L" bracket that the phillips style screw fastens to. The bolt fastening that bracket to the motor has oil pressure behind it. If it leaks the o-rings are first suspect but leak is actually coming from the bolt, I forget how the bolt seals ???
See cb500/550 Service Bulletins (#8 -valve cover) here:
http://www.sohc4.net/index.php/cb500/cb500-tech-guide/
« Last Edit: July 08, 2012, 01:53:26 PM by That 70s Bike »
« Reply #11 on: July 08, 2012, 10:07:37 PM »
And yet, this thread was about a CB550.  So, what is your point?  Buy a different bike?
Offline Cvalero
  • CB550 owner, hackanic on the side
« Reply #12 on: July 09, 2012, 06:30:47 AM »
 ;D
71 through early 76's have a rockerbox whose rocker shafts rotate when the valves open and close.  This causes the rockerbox and rocker shafts to wear quickly.  There was a alteration sold by honda to fix this issue back in the day but the quick fix is to take four extra cam end cap o-rings and place them in the rocker shaft hole, up against the shaft.  When the end cap is reinstalled it will compress the extra o-rings stopping the shaft from rotating.  I had read this on a website and did it when I redid my top end.
1974 CB550 (project)
1977 CB550
« Reply #13 on: July 09, 2012, 11:55:00 AM »
The oring "fix" only works if the shaft holes aren't already worn.    Once worn, an unworn replacement is the only cure.   The shaft holes don't wear uniformly.  One side of the shaft wears oblong more than the other end, which tilts the rocker and biases the cam follower face to make contact more on one side of cam lobe.  This greatly accelerates wear on both the rocker follower AND the cam lobe.  Severe examples need the rockers, cylinder cover, and cam replaced.
 An earlier post about this:
http://forums.sohc4.net/index.php?topic=20408.msg212239#msg212239
Offline Cvalero
« Reply #14 on: July 09, 2012, 12:53:45 PM »
Thanks for the clarification.  I actually didn't know this so you know I'm going straight home and taking by rocker box covers off to check for ununiform wear.  My bike has about 13k miles on it so hopefully I'm stll alright.
Sorry, appears this thread has gotten a little off topic.
1977 CB550
  • SEE YOUR AD HERE!
« Reply #15 on: July 12, 2012, 11:12:35 PM »
when you said "those rubber boots..." and didn't emphasize only the 550 boots" I took "those" as any CB 4 cyl rubber airbox boots & felt Honda would offer them if they offered for the cb750. I checked & you are correct, one part # for plenum w/boots and no longer available. Thankful for David S.Spares as I need one set for a 550 project.
