Author Topic: Need a little help here.... 78 CB550K  (Read 2189 times)
Offline kweb
    • The Webber Project
« on: July 04, 2012, 06:06:09 pm »
Hey,
I have been putting my 78 CB550 K back together and have been having one problem after another : ) But I'm having fun right! I have put my newly powdercoated wheels back together and have a question on the rear. The bearings are in, and I have assembled the wheel per the clymers manual. Once completely assembled I seem to have a little, very little play on the rear sprocket and the aluminum piece that the sprocket bolts to. I believe the bearing is completely seated and I have hit the heck out of the retaining ring.... Is a little play normal?
Thanks...
Offline kweb
Re: Need a little help here.... 78 CB550K
« Reply #1 on: July 04, 2012, 08:02:50 pm »
bump
Offline luap
  • LAWL
« Reply #2 on: July 04, 2012, 10:50:26 pm »
for me. I needed to beat the sprocket on the powdercoat takes up just enough so the sprocket doesnt seat properly also can cut off PC with razor blade. Me I wouldnt ride it until its tight
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline kweb
« Reply #3 on: July 05, 2012, 06:09:38 am »
The sprocket itself is not loose. It is the drive flange which the sprocket is attached to that has a little room to move. The wheel bearing is seated on the inner race, and the bearing retainer is seated against that bearing, however there is still a small gap between the bearing retainer and the drive flange. Any other ideas?
Offline kweb
« Reply #4 on: July 05, 2012, 10:45:28 am »
So I went ahead and disassembled the wheel again and pulled the bearings out. I believe what is happening is that the bearing that I have installed (new) is just a smidge too tall. Without the bearing the retainer collar screws down and everything is tight, with the bearing it stands up about a 1/16 of an inch. The wheel bearing in question has a part number on it of 6305NSE and was ordered from bikebandit. does anybody have any experience with this? I searched around but found nothing...
Thanks again.
Offline kweb
« Reply #5 on: July 05, 2012, 12:30:09 pm »
Anybody have any ideas on this... it's driving me nuts!  :o
« Reply #6 on: July 05, 2012, 12:45:48 pm »
I can't ascertain exactly what you are talking about.
Review this to ensure you have all the required parts:
http://www.westernhillshondayamaha.com/fiche_section_detail.asp?section=2036824&category=Motorcycles&make=HONDA&year=1977&fveh=123325
Then either post a picture showing your perceived issue.  Or, refer to the parts list numbers to indicate where your issue exists.
Offline kweb
« Reply #7 on: July 05, 2012, 05:32:50 pm »
Hey, thanks for the response. This is the fiche that I have been going off of.
http://www.bikebandit.com/houseofmotorcycles/1978-honda-cb550k-rear-wheel/o/m9449sch401615
 My problem is with the bearing (#26) and the retaining ring (#3). This fiche is misleading because the retaining ring actually goes after the final drive flange (#8). Without the bearing everything seats fine and the flange is tight. With the bearing in all the way the retaining ring (#3) sits up on the flange about 1/16 and the flange has a little wiggle room.
Is this clear as mud?
thanks
« Last Edit: July 05, 2012, 05:46:22 pm by kweb »
« Reply #8 on: July 05, 2012, 06:09:13 pm »
It's been 10 years + since I had my 78 Rear wheel apart.
I looked at my Fiche for the 1975 CB550F.  I think it has a better orientation/association of components.  I don't know if there is a specific oddity/difference between the F model and the 77-78 K models.  I had assumed no, but could be wrong, I suppose.
Anyway, for your parts list reference, I will ask if you have #9 and #10 in place when you tighten down #8.
Did you compare the old bearing width to the new bearing width?
Just fishing for answers, I guess.
bollingball
« Reply #9 on: July 05, 2012, 06:30:10 pm »
Check it against the other like TT said if they are the same I would think it is not seated. The 6305 sounds right not sure about NSE Is this a single seal?
Ken
Offline kweb
« Reply #10 on: July 05, 2012, 06:32:11 pm »
Yes, its a single seal. Not sure about the width.. I'm not sure if I still have the original bearing unfortunately... I tore down the wheel months ago and may have pitched the destroyed bearing.
Offline kweb
« Reply #11 on: July 05, 2012, 06:33:54 pm »
I can see that it's seated so it must be a little wider than the old one. I don't get it as this is the honda part number for the bearing that I need.... ugh. I can't believe that noone else has had this issue....
Offline kweb
« Reply #12 on: July 05, 2012, 09:38:28 pm »
I've been doing some research and am thinking now that the rubber rear wheel dampers (#4) may be worn.. Could this cause my drive flange to rock a little bit?
Offline Onetrackmind
« Reply #13 on: July 06, 2012, 03:19:07 pm »
Hi kweb,
I had the same problem, and found this thread when I searched this forum:
http://forums.sohc4.net/index.php?topic=84537.0
I tried something similar to what he did, but have not road tested it yet.  I didn't alter my wheel, and the bearing is fully seated, I don't know why there is a gap now between the drive flange and the retainer.
« Last Edit: July 07, 2012, 04:56:51 am by Onetrackmind »
