Author Topic: H4 headlight conversion for 350/400F  (Read 9707 times)
Offline fmctm1sw
« on: July 04, 2012, 08:29:57 pm »
I know I saw a thread here where someone took apart a headlight and put a modern bulb in it.  I'm pretty sure it was for the small fours with the 6-1/2" headlight.  I can't find it for the life of me.  Anyone know what I'm talking about?
Notes to self:  http://store.candlepower.com/lowwaca61quh.html
« Last Edit: July 04, 2012, 08:57:42 pm by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline CB500_k2
  • Wrenching makes a good retirement.
Re: H4 headlight conversion for 350/400F
« Reply #1 on: July 05, 2012, 10:22:46 am »
I purchased a model 8022 headlamp from Candlepower for my CB 400.  It was a good fit.  See attached picture.  To deal with the limited alternator output I installed a Phillips EcoVision H4 bulb which claims 10% extra brightness and 20% less power consumption than the standard 55/60 bulb.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline david 750f
  • 1976 CB750F
« Reply #2 on: July 05, 2012, 10:28:31 am »
The EcoVision bulbs are great.. They actually only draw 44/48 watts and Philips claims they are brighter than the 55/60 bulbs.. I think I paid around $15 for a pair.
1976 CB 750F
Offline Trevdawg
« Reply #3 on: July 05, 2012, 10:29:49 am »
Interesting.
Offline Grim
« Reply #4 on: July 07, 2012, 12:12:42 pm »
Thanks for the info! Did the mounting brackets on the 8022 line up with the screws on the 400? I've got a 350F with a 5 3/4 bucket, just picked up full sized bucket but wanted to see if I could get one of the Candlepower units in it without having to do any alterations to the brackets.
Offline fmctm1sw
« Reply #5 on: July 07, 2012, 03:28:14 pm »
Check this auction out.  Guy claims he specifically did it on a 350F.  There's going to be some tinkering required though...  http://www.ebay.com/itm/Headlight-H4-Upgrade-Universal-162mm-6-3-8-CB360-GS400-RD400-See-Notes-E35-/230805971359?pt=Motorcycles_Parts_Accessories&hash=item35bd1ba19f&vxp=mtr
Quote from:
THIS LISTING IS FOR ONE NEW H4 HEADLIGHT UPGRADE KIT. THIS KIT INCLUDES THE LENS/REFLECTOR ASSEMBLY, 60/55 12V BULB, AND DUST BOOT.
    THIS 162mm (6-3/8") HEADLIGHT IS A UNIVERSAL REPLACEMENT INTENDED FOR MANY MODELS AS LISTED BELOW, AND MAY HAVE MOUNTS OR TABS THAT ARE NOT USED ON YOUR BIKE.  BE SURE TO MEASURE YOUR ORIGINAL HEADLIGHT OR HEADLIGHT RING PRIOR TO ORDERING TO BE SURE THIS WILL WORK FOR YOUR CURRENT SETUP.
    EVEN THOUGH THE MANUFACTURER CLAIMS THIS TO BE DIRECT FIT, IT IS LIKELY THAT SOME MODIFICATIONS WILL BE REQUIRED TO INSTALL THIS. WE HAVE PERSONALLY USED THIS LAMP ON HONDA CB350F, CB360, AND SUZUKI GS400 WITH ONLY MINOR MODIFICATIONS.
    SINCE THIS ITEM IS NOT AN OEM PRODUCT, THERE MAY BE DIFFERENCES IN APPEARANCE AND/OR FIT AS COMPARED TO THE ORIGINAL PARTS (SEE LAST 5 PHOTOS ABOVE FOR COMPARISONS TO OEM LAMPS), BUT THE MANUFACTURER HAS DESIGNED THIS TO FIT ALL THE MODELS LISTED BELOW.
    ON SOME MODELS THERE MAY BE A DIFFERENCE IN DIAMETER: THIS LAMP IS 6-3/8" DIAMETER (162mm) AS COMPARED TO THE ORIGINAL SEALED BEAM DIAMETER OF 6-1/2"-6-9/16" (162mm-167mm), WHICH MAY LEAVE A GAP BETWEEN THE TRIM RING AND THE LENS. ALSO SINCE THE LENS ON THIS LAMP IS MORE "FLAT" THAN THE CONVEX LENS ON OEM SEALED BEAMS, IT MAY SIT DEEPER IN THE HOUSING THAN ORIGINAL LAMPS.
    MODIFICATIONS MAY BE REQUIRED ON SOME MODELS PARTICULARLY WITH THE BEAM ANGLE ADJUSTED HOLE ON THIS LAMP (SEE PHOTO 5 ABOVE FOR AN EXAMPLE OF MISALIGNMENT AS INSTALLED IN A CB360 TRIM RING). THIS MODIFICATION IS USUALLY LIMITED TO BENDING THE HEADLIGHT BEAM ADJUSTER TAB.
THIS KIT IS A DRAMATIC UPGRADE FROM THE LOW PERFORMANCE SEALED BEAM HEAD LAMPS ORIGINALLY FITTED, AND ALLOWS EASY AND INEXPENSIVE REPLACEMENT OF THE BULB USING A STANDARD H4 BULB AVAILABLE AT MOST MOTORCYCLE AND AUTO PARTS SUPPLIERS. THE TERMINAL ARRANGEMENT WILL FIT YOUR EXISTING ELECTRICAL CONNECTOR PERFECTLY.  OUR STOCK PHOTOS OF ACTUAL ITEMS SHOWN.
*NOTE: SOME MODELS THIS PART FITS NEED TO USE A LOWER WATTAGE BULB (35/35 OR 45/45 WATT). THIS BULB SUPPLIED WITH THIS KIT IS 55/60 WATT. WE CAN SUPPLY A LOWER WATTAGE BULB FOR $7.00 EXTRA. PLEASE SEND US A MESSAGE WITH EITHER BIKE YEAR AND MODEL, OR WATTAGE DESIRED.
MAKE/MODEL:
1981-1982 Honda CM200T*
1991-2000 Honda CB250 NIGHTHAWK 250*
1982-1983 Honda CM250C*
1973-1974 Honda CB350F
1974-1976 Honda CB360* (ALL)
1974-1975 Honda CL360* (ALL)
1975-1977 Honda CB400F SUPER SPORT
1978          Honda CB400A
1980-1981 Honda CB400T HAWK
1978-1979 Honda CB400TI
1978-1979 Honda CB400TII
1979-1981 Honda CM400A
1979-1981 Honda CM400T
1980-1981 Honda CM400E
1981          Honda CM400C
1982-86     Honda CB450SC NIGHTHAWK 450
1982          Honda CB450T HAWK
1982-1983 Honda CM450A
1982          Honda CM450C
1982-1983 Honda CM450E
Also suits:
Suzuki GS400 All
Suzuki GS425 All
Suzuki GS450 All
Yamaha RD400 All
Yamaha XS400 All
CONDITION:  NEW
OEM INTERCHANGE PART#:
Honda 33120-333-670
Kawasaki 23007-059
Suzuki 35121-44611
Yamaha 1A0-64320-61-00
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline CB500_k2
« Reply #6 on: July 07, 2012, 05:55:07 pm »
The Candlepower unit fit in without any modification.  I originally bought if for a CB350 and it fit fine.  I then moved it to my more recently acquired CB 400.
1973 CB500
1974 CB350 - sold
Offline 400f newbie
  • bought a 400f after 48 years absence from bikes
« Reply #7 on: July 18, 2012, 04:29:42 am »
looking at david silver spares facebook page and he has a lot of new 400f parts coming on line soon.
        these include headlight with h4 fitting,new type of cam adjuster,new chain guard.
         also on his webpage,there are a lot of new 400f articles.just click on d.s. stories.sorry about not adding links but i am computer illiterate.          ray. also a mention that the 400f2 model was fitted with longer head bolts which cured oil leakswhich occured on earlier models
started @ 16 with bianchi 75
           @ 17 with moto guzzi 175
best part was that i had to go to the home of stanley woods for parts.
a legend and a gentleman.
Offline Fred T
« Reply #8 on: July 18, 2012, 07:26:59 am »
I changed my CB400F bulb for a 45/45 H4  and I´m happy with it.  Anything that draws more than that will deplete your battery quickly.
Offline Sniper X
  • Resistance is not futile, it is voltage devided by current.
« Reply #9 on: July 18, 2012, 07:54:32 am »
Can the stock CB350F/400F stator be rewound to put out more juice like most other bikes can?
1973 CB350 Four, 1969 CL350 Scrambler (2) 1985 BMW R80RT.
