Author Topic: Salt Racer CB 750 OZ style  (Read 169767 times)
Offline johno
Re: Salt Racer CB 750 OZ style
« Reply #1075 on: February 06, 2015, 03:31:53 AM »
So put the bike on the rollers, fuel, battery etc, fan in front cos its hot kind of day.
Had trouble with the rollers, I converted them from the 240 volt motor last year to 12 v ford V8 starter, no way was speed high enough to start the ol girl, tried pushing down the road, #$%*e myself nearly fell ofwith crazy peg position and the 10 deg lock, man it feeels real strange with no lock at low seeds, SO got a 24 v battery  out of the forklift and BAM instant start up man, perfect run sweet , bit rough for about a minute then smooth as a babies Bum , sharp throttle , real Horny cam lump at under 4K, ooooh I love horny cam lump man. 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) ;D
So all sounded good,  the video is from front so the sound is not as loud as it really is, but overall was nice to get the bike running and having it sounding nice.    Booked the dyno 26 th Feb
Will do a run with the NGK fuel AF meter for a few miles to get the jetting closer ready for dyno, cant wait to ride it at a speed where it feels safer.
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
« Reply #1076 on: February 06, 2015, 03:44:45 AM »
So far so good johno. I know that has to feel great.
« Reply #1077 on: February 06, 2015, 04:37:10 AM »
I have to admit I am excited. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #1078 on: February 06, 2015, 05:25:57 AM »
+1. What he said! Go Johno! K. Bill
BentON Racing Website
BentON Racing Facebook
Offline Old Scrambler
« Reply #1079 on: February 06, 2015, 06:13:19 AM »
Very KKKKOOOOOOOOLLL 8) 8) 8)
Nice Pipe ;)  Ride Report from the MASTER is a must ;D ;D ;D ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #1080 on: February 06, 2015, 06:15:11 PM »
hell yeah!!
« Reply #1081 on: February 06, 2015, 06:32:15 PM »
Why so little steering lock? I had my bike set up with only about 25* once due to interference with the gas tank, and it sucked eggs. Dropped it once just pushing it into the shop. :o Maybe I've spent too much time playing in the dirt, but once you can't steer into the skid, so to speak, you're #$%*ed. ;)
Offline johno
« Reply #1082 on: February 07, 2015, 12:33:23 AM »
Spot on Scottly, ;D
It is probably OK out on a big flat salt pan where you instinctively use balance not steering but at slow speed you suddenly realise how much steering is used.
Tiny's best advice for rookies to the salt was get your crew to catch you when you come back to the pits after your first run, lots fall off as they swing back into the pit area and forget no lock available  :-\
Both USA and Oz land speed organisations set min lock , I guess thinking it will reduce the speed wobble impact ???? doesnt do it for me , I prefer double dampers with plenty of lock to steer into a slide to get out of trouble.
The real impact I found is just putting bike off and on trailer or shifting around the workshop,    serious pain.    I will likely change my welded on lugs to adjustable like Dennis has on his, while foolin in the shed just back the screws out for some decent lock. Dennis probably been through the inconvenience and come up with the adjustable screws....I like it.
Also Scot, I know your a spark man, I finally got the power arc system sorted with help from Garry the owner.  Not sure what the deal will be on the dyno as normally the dyno uses a spark plug lead pick up for tach etc , apparently cant happen with this system cos it has 3 sparks, maybe the dyno pick up could be changed to the bikes tacho output wire ????? dunno will have to find out on the day.
cheers johno
cheers Johno
« Reply #1083 on: February 07, 2015, 06:17:36 AM »
I have used the tach output wire from the ECU to pickup the signal....that's all you can do on modern bikes with stick coils.
« Reply #1084 on: February 07, 2015, 07:33:50 AM »
Credit goes to Dave Murre for my adjustable fork-lock screws................but thanks for noticing.............I just replaced them with SS units to cut down on rust.
I am waiting on you to 'test' the power-arc system.  Then may acquire instead of a Dyna 2000 ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #1085 on: February 07, 2015, 10:15:02 AM »
With my Gerex multispark ignition, I used one inductive secondary pick-up on the #1 plug wire, and a second pick-up on the #4 wire. I don't have a method of using a tach output on my Dynojet??
« Reply #1086 on: February 07, 2015, 12:23:38 PM »
I'll ask Rick Stetson about that for you. ;)
« Reply #1087 on: February 07, 2015, 06:07:29 PM »
Thanks, Mike. 8)
Offline johno
« Reply #1088 on: February 10, 2015, 12:18:04 AM »
Well I finally managed to get something on the u tube, hard for a technosaurus like me.
Please note after getting flustered trying to get the rollers sorted , getting a decent video clip went out the door and all I could get off one of the guys was a short phone clip just as it burst into life,      it is slightly rough as it is cold etc it wouldnt hold constant throttle without cutting out so lots of arm action to keep it going but after about i minute warmed up it sound nice held constant throttle etc revved clean / crisp to about 8 K
I was never meant to be a movie star, now I can do this u tube thing I will have another go as soon as the heat wave cools down
If your interested Go to utube type on "Honda 750 mellow yellow" and up she comes
cheers johno
« Reply #1089 on: February 10, 2015, 02:24:16 AM »
Its alive..!!   ;)
Offline cbornotcb
    • Photobucket link
« Reply #1090 on: February 10, 2015, 03:18:04 AM »
 ;D ;D ;D
Offline hotdog
« Reply #1091 on: February 10, 2015, 03:25:41 PM »
Annnnd heres the link Johno...regards.
https://www.youtube.com/watch?v=Qi3vMNQe2gk
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline mick7504
« Reply #1092 on: February 10, 2015, 05:39:25 PM »
cheers johno
You are now johno.  ;D
That's magic mate.
If I was you
I'd be worried about me.
Offline Bootsey
« Reply #1093 on: February 10, 2015, 06:59:16 PM »
That's awesome, great build thread.
Offline bear
  • Leeton in Australia
« Reply #1094 on: February 10, 2015, 11:57:01 PM »
Sounds gooooooood..... ;)
Brian
Offline johno
« Reply #1095 on: February 11, 2015, 12:23:06 AM »
Thanks for link hotdog, you are a true techno head ;) ;D
I asked around re the dyno tacho wire thingo, apparently it depends on the type of dyno , some use the no. 1 lead pick up, some can be converted to a tacho output wire from module and some dont need anything as they use the drum rotation pick up, so I'll have to find out what model this bloke has.
cheers johno
Offline Greg H
  • When two cams is one too many .
  • Still crazy after all these years .
« Reply #1096 on: February 11, 2015, 12:59:34 PM »
The bike sounds good mate  ;). Looking forward to seeing the next episode .
« Reply #1097 on: February 11, 2015, 01:07:23 PM »
Sounds somewhat familiar ;)
Taking video while parked or on the dyno is one thing...........................trying to keep the bike in the camera lens at 155-mph is another ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #1098 on: February 22, 2015, 10:17:39 AM »
So its Sunday night in Oz...................it must have rained all weekend ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline johno
« Reply #1099 on: February 22, 2015, 01:37:51 PM »
Hi Den,
wished it did rain :) lousy 40 plus all weekend.
I am all set to run the bike on her majesty's test track as I want to get 10 minutes of run time before I put on dyno next weekend.
Its just too hot to run the ol girl and where I live its too dangerous early morning or evening when it cools enough, bloody roos everywhere :'(
Just been busy doing the hundreds of little jobs ,  and sweating a lot.    I'm sure you understand Den
