Author Topic: Salt Racer CB 750 OZ style  (Read 195970 times)
Offline bear
  • Leeton in Australia
Re: Salt Racer CB 750 OZ style
« Reply #125 on: December 11, 2012, 05:38:11 PM »
Nice pic mate, don't worry about the pink shirt. ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
They call it "Man Salmon" down here Sammy. ;D ;D
Brian
Offline johno
« Reply #126 on: December 11, 2012, 07:02:47 PM »
Bear , I couldnt believe it when I read your plight, its crazy.  to me it opens a can of worms and raises more questions than answers.    Selfish me I'll be gutted, you dont know how much I want to hear a big HP sohc honda at full noise with no muffler.   Mufflers and meds are the same to me , both undesirable. >:(
I blame mufflers for the demise of crowds at speedway, god I hate mufflers ! an open exhaust is like a musical instrument with a beautifull range of notes , mufflers sound like a fart in the pants.
All that aside Bear keep pushin your case if you can, with your ponies your a real chance to to get a result, oh and I get to hear some real music. ;D ;D ;D
johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline johno
« Reply #127 on: December 11, 2012, 07:15:34 PM »
Just playing with head gaskets.  with the small cc motor 750 cc In the old days I used to scallop the top of the barrels to get a better flow past the restricted area of the inlet valve, It was easy to do as Honda graciously made the head gasket on those lines as per pic. I never had a flow bench in those days but it felt better ??? so I regularly done that mod on the standard bore stuff.    I am planning a bash on the bench next week and this will be one of the mods I want to quantify.  Has anyone else done this in the old days, I usually scribe a line one mill above the top ring position and grind down to that, I had a bad day once and went fraction low so that you could see the top ring but run with it and never had an issue with sealing or reliability , was a roady.
Be interesting to see how much increase the flow rate was.      I did flow this an several car type engines so I know it really helps the cause on the small bores  so keen to get the numbers on my favourite motor.
johno
Offline johno
« Reply #128 on: December 11, 2012, 07:18:17 PM »
just another pic to help show whatt Im talking about, the outside edge of the inlet valve is restricted by the small bore
Offline johno
« Reply #129 on: December 11, 2012, 07:23:29 PM »
With the gaskets I bought the copper and composite are both made round not like the standard honda ( bottom gskt with two egg shapes) so my option is to use the standard Honda or use the copper and grind the valve relief carefully into the gasket ! :D
johno
Offline johno
« Reply #130 on: February 18, 2013, 09:32:43 PM »
Well !   No 3 crankcase, I made sure it was good on the outside this time,  only to find it had run a main bearing for some reason. It looks as if it may have been put together after a rebuild with wrong bearings.
I will post a couple of pics to show how the heat from the bearing as damaged the thrust face on the cases.
This is the last straw, gunna have a dummy spit and time out  :( :( :(
Offline johno
« Reply #131 on: February 18, 2013, 09:37:31 PM »
Thought I would show something positive for a change,
My first love , a 72 K2 which I bought new,  and my late fathers original Kwaka H1 500 that we used to have some great drags with each other. ;D ;D ;D
johno
Offline johno
« Reply #132 on: February 18, 2013, 09:44:16 PM »
YAHOOOOOOO   live action, off to the salt for a look and learn annual speed week. ;D ;D ;D ;D ;D ;D ;D ;D
Lake Gairdner,  baby this is from a remote area with no phone coverage and I have had to do a deal with the CIA to get these pics through over the next cpouple of days LOL ( thats what it feels like anyway) ;D
about 200 kilometers of dirt to the lake, today Monday is 43 to 45 degrees celcious on lake with lot and lots and lots and lots of flies :(
Offline johno
« Reply #133 on: February 18, 2013, 09:48:20 PM »
First view of the salt. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D  looks  flat and fast baby,
johno
Offline johno
« Reply #134 on: February 18, 2013, 09:50:47 PM »
Down onto the lake edge we go, got to use a blower to get rid of the red dust from the road before accessing the lake
Offline johno
« Reply #135 on: February 18, 2013, 09:53:55 PM »
Salt has wind wave kind of effect from the recent flood and they DLRA club has graded the main tracks smooth like ice
Offline johno
« Reply #136 on: February 18, 2013, 10:04:07 PM »
By the way just so there is no confusion I didnt get the bike finished, just look and learn this year.
For those following the thread you will remember I chose a soft class to tackle with the Honda that being
750 MF        I wanted to rub gas  ie 750 MG but the record for gas was 150mph and the record for fuel was 90mph so I thought easy choice.
Well so did this bloke with his 750 water bottle,   his bike is a gas bike but on the number plates he has 750 MF so he can set the MF record and then he reverse the number plates with MG750 so he can then have a crack at the gas record.     So he is the man I have to beat, i,ll keep you updated on his runs over the week.
The bike has been put together by a club from Port Pirie in SA and is traditionally a strong performance club.    Good luck to them, will only make the challenge more fun  ;D
Offline johno
« Reply #137 on: February 18, 2013, 10:09:46 PM »
Another shot of the suzy,   is doing things different to me with his with std rake but long swing arm to get the  xtra wheel base , he is running the same sized wheels as everyone does, where I will take advice from fellow forum members and run tall skinny wheels 21 inch narrow and buffed tread etc for speed rating,
I notice 90 % of the bikes run really loose chain tension , must try it.
ciao johno
Offline johno
« Reply #138 on: February 18, 2013, 10:12:58 PM »
The boys heading off to scrutineering.
Offline johno
« Reply #139 on: February 18, 2013, 10:17:12 PM »
Some sidecar pics for Bear and the other sidecar boys.  There are different styles and I learnt today they dont run passengers , just ballast like tool box or cast lead or steel in the best spot to get the best balance,
you would get lonely out there Bear ! ;D
Offline johno
« Reply #140 on: February 18, 2013, 10:19:13 PM »
Just thought I would show the carbs Scottly !
Offline johno
« Reply #141 on: February 18, 2013, 10:21:04 PM »
weird chairs for me
Offline johno
« Reply #142 on: February 18, 2013, 10:23:26 PM »
This baby might be an adrenilan rush boys , fair dinkum you sidecar blokes are crazy baby. ;D ;D ;D
Offline johno
« Reply #143 on: February 18, 2013, 10:33:41 PM »
Mate !  was driving to the lake in the middle of the desert and came across this , peed myself laughing, the people who own the sheep station must have got bored and had an old boiler,  they put a conning tower and gun on the front, last thing I expected to see in the middle of nowhere ! ;D ;D ;D ;D
Offline bear
« Reply #144 on: February 18, 2013, 10:41:56 PM »
I'm pissed off I'm not there mate.
If you see a funny little fella wandering around wearing a top hat, his name is Max Hopper say g'day for me.
I think that red GSX might be his.
Keep sending the photos mate, good stuff.
Brian
  • Moderator
« Reply #145 on: February 18, 2013, 10:59:08 PM »
Morning Brian and Johno, great pics mate, is the event still on or are you back home, just wondering how you posted pics/report with no phone coverage.
If you're still there, look out for my mate Tiny running a blown CBR250.
Sam. ;)
Offline mick7504
« Reply #146 on: February 18, 2013, 11:02:45 PM »
Great stuff johno and great photos too mate.
Who are the Pirie boys?
Might know 'em from the old stomping ground.  ;D
If I was you
I'd be worried about me.
Offline johno
« Reply #147 on: February 18, 2013, 11:59:02 PM »
Is this his bike Sam ?
I,m still here but will pack up and leave about 7pm,  have a 8 hour drive home tonight for work tomorrow :(
Its hot and #$%*ty here with the flus boys but there is some seriously good bull#$%* going on at the bar.
Sam its the organisers Sat Nav phone thingo  which evan the media cant use , just bang in my Telstra account and its hot off the press as they say,  but hey thats what mates are for  Mums the word.
Offline johno
« Reply #148 on: February 19, 2013, 12:03:30 AM »
Sam this is the bloke you put me onto when I first joined the forum looking for advice.  he is still at it,  being the worlds fastest Postie bike Honda CT110, is a nice bloke.
cheers Johno
Offline johno
« Reply #149 on: February 19, 2013, 12:10:51 AM »
I thought this old Honda CX 500  was interesting current OZ record holder,  as he had a unusual steering damper on the front which works and complies with regs, its off a CR450 Honda and is a small vertical mount type on heim joints, costs about $400 oz but nice and easy to mount in tight spaces, I tried it by shaking the steering and it works a treat,
just bolts to the head stem.
johno
