Author Topic: Salt Racer CB 750 OZ style  (Read 169654 times)
Re: Salt Racer CB 750 OZ style
« Reply #1250 on: September 09, 2015, 11:29:58 AM »
Looks very nice johno.....3rd time is the charm. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #1251 on: September 09, 2015, 01:23:18 PM »
I don't like buttons either. Sometimes no cut for clip, Bill
BentON Racing Website
BentON Racing Facebook
Offline hotdog
« Reply #1252 on: September 09, 2015, 01:33:54 PM »
Looks good Johno, here's to you having some better luck this time round - you'll go well.
Dyna should solve any ignition problems...
Instagram - Lumpy Cam Motorcycles
FB - Lumpy Cam Motorcycles
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline cbornotcb
    • Photobucket link
« Reply #1253 on: September 09, 2015, 01:45:39 PM »
Looking GOOD Johno  ;) , almost too good to use  :o
I use spiral lock clips in my HD, maybe they are available in smaller sizes ? , no way they can fly out (hard enough to dig out once there in)
Offline johno
« Reply #1254 on: September 10, 2015, 02:02:07 AM »
On the 750 I have gone for a different back end, 6 inch longer swing arm, 19 inch front wheel on back, cb 125 R disc and caliper etc, flirting with the rules by having some style in my rear fender / seat combo.  Got to be catefull or if deemed aerodynamic puts me into PS class or partial streamling , tougher record.
ciao
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline johno
« Reply #1255 on: September 10, 2015, 02:04:28 AM »
board racer action baby
Offline johno
« Reply #1256 on: September 10, 2015, 02:07:55 AM »
Check out the difference between the stock disc and the CBR 125 disc, the ally I ordered for rear wheel spacers disc and sprocket carriers spacers should arrive tomoz so will do some lathe action on the weekend
« Reply #1257 on: September 10, 2015, 02:23:12 AM »
looking good Johno, lets hope the motorcycle Gods are in your court this time.... ;)
Offline hotdog
« Reply #1258 on: September 10, 2015, 03:22:16 AM »
Johno, have you got any plans to check the timing on the dyna..? How is it fired..? hall, digital, dare I say it...optical. What I'm trying to say is- can you check each individual cylinders firing interval with a laptop for that Dyna.?
Offline johno
« Reply #1259 on: September 10, 2015, 05:55:40 AM »
Hi Hotdog,
I wasnt planning on doing anything special with regard to checking the setting of the timing, was hoping to get something sorted so I didnt have to worry about synching the cylinders.  chose the dyna 2000.with matching coils and leads etc.  cos it was cheaper than the MSD  :)  it does have the ability to have 4 preprogrammed advance curves in, and those curves can be modified by laptop if desired.
It also can synch cylinders 1&4 and 2&3 if you have a need to do that.   Most of the 4 stroke cranks are well indexed unlike say 2 stroke cranks which are often 2 or 3 degrees out after a rebuild so wasnt planing to use the function. Dyna promote it as an ability to assist in temp control of middle cylinders but at this stage Ive gone from trying to be a  hero to just trying to get to the other end of the lake. ::)
Unless I have issues on the dyno I will start with timing off no 1 as usual, no index checking.
To find out the timing variation on the 4 coil power arc system I had to put a degree wheel on the alternator end and rotate the crank and watch for the spark to zap on each cylinder while observing the angle it fired.  Discovered the  20 deg or more variation between 1&2 and 3&4 .   It was hard at slow speed so I used an air drill on the crank end and a strobe light on each cyl lead
Interesting the unburned fuel in the exhaust made for real horny exhaust noise, pity it was so slow.  :(
« Reply #1260 on: September 10, 2015, 06:15:33 AM »
Hall sensors
Offline Old Scrambler
« Reply #1261 on: September 10, 2015, 08:27:19 AM »
With available ignition programming..............the dyno-test should indicate the 'sweet-spot' but you may want to stay near stock for starting and warm-up........and maybe the lower gears.
I don't know your rules..............but suggest bringing the tail to a point (upside-down canoe-shaped) or rounded...........and extend the tail as far as the rules allow.
Looks like new shocks...............check the sag with the rider weight and then full compression to have clearance under the tail...........my springs were good on first check.........then sagged after a few bumps...........
Waiting to see your dyno-chart ;D ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #1262 on: September 10, 2015, 10:24:36 AM »
Oh come on Dennis! You know that sag was caused by that good Mexican food and a 'few' cold brews LOL (I'd insert a  smiley here if they worked on this new computer?)
Offline hotdog
« Reply #1263 on: September 10, 2015, 12:43:40 PM »
Thanks John and Mike,  just going through thoughts in my head is all - would like to see this thing kick arse, especially after the time and $ invested.
I agree johno, crank indexing shouldn't be an issue - I didnt realise the power arc was 20' off..? What did they say when you presented that fact to them..? Or am I bringing up the past here....
Dale.
Offline cbornotcb
    • Photobucket link
« Reply #1264 on: September 10, 2015, 03:36:30 PM »
ciao
"Deemed advantageous" related to anything FORWARD of the rider Johno, the rear has limits on how far it extends in relation to the rearward edge of the rear tyre, and it's height
Tiny
Offline johno
« Reply #1265 on: September 10, 2015, 03:51:47 PM »
Thanks Tiny,
I bumped into a Bruce Fergy in Mildura yesterday, started talking about the bike when your name popped up, he called you a hopeless salt tragic  ;) and said to say hello on his behalf  ;D
« Reply #1266 on: September 10, 2015, 05:24:24 PM »
Dale.
Thanks Dale...that just about says it all for me too. I just want see it work close to its potential. ;) Johno is on the right track. ;)
« Last Edit: September 10, 2015, 05:26:26 PM by MRieck »
Offline cbornotcb
    • Photobucket link
« Reply #1267 on: September 10, 2015, 06:59:38 PM »
Thanks Tiny,
Bruce is an expert at destroying engines Johno, Hi back if you bump into him again,,,have you downloaded the 2015 DLRA rule book ?
http://www.dlra.org.au/rulebook.htm
Offline johno
« Reply #1268 on: September 10, 2015, 09:05:23 PM »
Thanks for the words of encouragement folks ;D
I'll make a statement I can be held to. If the bike is still running mechanically sound after the next speed week, I'll send it over to the US so some of our forum folks can have a play at Bonny and give Dennis some company.
I intended to do that this year but things didnt turn out as expected,  ::)
Offline johno
« Reply #1269 on: September 10, 2015, 09:07:03 PM »
I like Jerry's story better Den  ;D
« Reply #1270 on: September 10, 2015, 09:18:25 PM »
I would be honored to be a member of your US team, Mark. 8)
« Last Edit: September 10, 2015, 09:20:27 PM by scottly »
« Reply #1271 on: September 10, 2015, 09:39:45 PM »
Me three..
    • BentON Racing
« Reply #1272 on: September 11, 2015, 03:18:25 AM »
Need a rider? K You da man Johno  ;D Bill
Offline johno
« Reply #1273 on: September 11, 2015, 03:57:59 AM »
You blokes are crazy  :o but cool  8)
« Reply #1274 on: September 11, 2015, 09:07:05 AM »
Competition...........that's what its all about 8) 8) 8) 8)
We can get organized after FEBRUARY :) :) :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
