Author Topic: Salt Racer CB 750 OZ style  (Read 181017 times)
Re: Salt Racer CB 750 OZ style
« Reply #350 on: October 13, 2013, 08:06:33 PM »
Captain webber. ;D
I'm onto their web site now..... will let you know their responce, sounding like I'm heading up a creek in a barbed wire canoe.
ciao johno
Not a lot of technical info on their web site that I can find. I did notice they recommend a maximum spark plug gap of .032"? The Gerex ignition calls for twice that, but I admit I've only gone as far as .045". ;)
Offline johno
« Reply #351 on: October 15, 2013, 04:28:12 AM »
Hi Scottly,
The ignition mob got back to me today with this comment ; :(
Mark,
If you have a C4 for the CB 750 you would have 4 ST Coils 1 for each cylinder (you will need to know the firing order). Each coil will fire only in that cylinder giving full power to each cylinder and does not share the spark with another cylinder as in the normal wasted spark ignition but will also fire in its own cylinder in the exhaust stroke.
So to me Scottly your right and their full of it  ;)  their system is just the same as a normal wasted ignition as the modern wasted dual coils are really just two coils moulded together for secondary and they just share the primary.    Hope the spark is worth the effort.   Their claim to fame is the light sensor  pick up is more stable than a magnetic for more consistant , evan firing points.
Cheers Scottly, thanks for alerting me  ;)  johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline johno
« Reply #352 on: October 15, 2013, 04:49:20 AM »
Spent all Sunday mounting the coils, was a simple job but fabricating is not my strength, some blokes just look at something and get it right first up, I'm like an old tart and cant make my mind up.
I am trying to beat the salt if thats possible by using all stainless brackets and replacing most of the bikes on the bike with stainless.
Offline johno
« Reply #353 on: October 15, 2013, 04:52:44 AM »
got them mounted, the mount plate acts like a brace in that modified part of the frame and braces it well.
Offline johno
« Reply #354 on: October 15, 2013, 04:55:40 AM »
Well , this is what it looks like from the saddle.
Offline bear
  • Leeton in Australia
« Reply #355 on: October 15, 2013, 04:58:15 PM »
Hope it works out Johno. I've been a little dubious about these ignitions. Not shore the light sensors would be up to the rigors and heat stress they would cop in the tough environment we are likely to subject them to.
Brian
« Last Edit: October 16, 2013, 06:32:48 AM by bear »
« Reply #356 on: October 15, 2013, 07:34:17 PM »
I've yet to see a magnetic pick-up, either Hall-effect or reluctance, that displayed a +/- variance of 7 degrees with a strobe???
Offline johno
« Reply #357 on: October 15, 2013, 08:09:57 PM »
yeh Boys ! I agree ...........but hey I'll be the guinea pig. ;) ;D ;D ;D ;D
Cheers johno
Offline ogsmakdade
  • bike newb
« Reply #358 on: October 15, 2013, 08:33:05 PM »
that's a nice coil mounting bracket, great job!
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
Offline Old Scrambler
« Reply #359 on: October 16, 2013, 06:40:35 PM »
Now you have to make the tank fit over the coils............I'm seriously looking at an SL350 tank...........
Johno.........can you bend those clip-ons?  Try this...........hold your arms in front of you at about the current bar position. Now keep your thumb-knuckles steady and rotate your hands downward to an approximate 15 or 20-degree angle from vertical (similar to milking a cow)............but angled back to match the frame down-tubes...............notice how your arms, elbows, and shoulders all got narrower...........now rotate your wrists inward..........notice even more arm and shoulder narrowing.  If you measured the shoulder and arm width before.............it should be about 3 to 4-inches narrower when in the ideal speed-tuck position. I call that free HP and more MPH at the top end.
PS....remember to wax your leathers ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #360 on: October 16, 2013, 07:48:05 PM »
Do not wax the seat, or the seat of the leathers! ;) ;D
Offline johno
« Reply #361 on: October 16, 2013, 09:17:02 PM »
Den, thats why Ive got a jocky;  ;D ;D ;D Petes shoulders are allready 200mm narrower than mine, his belly is probably the same as mine , big  ;)  as he hasnt ridden much lately I hear ;) :)
Thinking I should make up a portable sauna so Pete cab drop a few Kilos half hour before the ride ???
Offline johno
« Reply #362 on: October 21, 2013, 02:10:14 AM »
Changed the wheel bearings on my rear mag on the weekend, made the groovy tool and the retainers came out like butter.
Sorry for doubling up but I posted this on the wanted parts thread , BUT its because I am desperate, I need the front 19 inch matching mag.    I am having a blood rush so if you have one or know where to get one I'll pay the silly money for it,
Tease me baby !
ciao johno
Offline sohc boy
« Reply #363 on: October 21, 2013, 02:52:54 AM »
....dont need sauna Johno , i'll go on my coffee n dry bread diet week before ... get under 50 kg's easy , jus bring plenty of velcro
i live by the voice inside my head
Offline bear
« Reply #364 on: October 21, 2013, 05:18:49 AM »
Jeez Pete..............you could cut off my arm's and legs and I would still come in over 50kg. :o
Brian
Offline Tintop
« Reply #365 on: October 21, 2013, 06:32:39 AM »
Still at 58kg, been there since my twenties Bear.   Free HP. ;) ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline bear
« Reply #366 on: October 21, 2013, 07:11:03 AM »
Bastards! I weighed in at 100kg at the age of fifteen.
Had to nearly kill myself, ate through a straw for two bloody months and I still couldn't get under 95kg.
Off to do the Southern Classic this weekend.
Newmo and I won it in 2011 just before the accident then Newmo won it again with a mate of ours in 2012.
So the pressure is on and I'm still riding like an old chook. ::)
Brian
  • Moderator
« Reply #367 on: October 21, 2013, 08:06:08 AM »
Hi Fatty,  ;D ;D ;D ;D when I was racing seriously, I weighed in at 147 lbs. The least I could weigh without carrying ballast was 126lbs. I had spent a small fortune making the bike light and thought, why am I making it pull 21lbs of body weight that it didn't need to.
I went to my doctor who was well in tune with what I was doing and he put me on three different diets over three weeks, not a bloody ounce came off. >:(
11 years later, the wife decided over night that she wanted me out of her life...three weeks later, I was 126lbs, WTF didn't she want a divorce 11 years earlier.  ;D ;D ;D ;D ;D ;D
I'm now 155/6lbs and don't give a fcuk.  ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline Tintop
« Reply #368 on: October 21, 2013, 09:39:42 AM »
Back in the 70's I was training horses in the UK & Ireland, and was offered a chase jockey job.  At 9 stone I made Grand National weight, and at 5'8 towered over the regular jocks.  Figured I wanted to live longer so I declined.   Can't say I'm the brightest bulb in the factory though, given I've decided to start racing sidecars as I approach pension age. ::) ;D ;D ;D ;D
« Last Edit: October 21, 2013, 09:55:24 AM by Tintop »
77 CB550 Cafe build
  • Moderator
« Reply #369 on: October 21, 2013, 09:42:44 AM »
I wouldn't have liked to be YOUR horse with 14 stone sat on me. hahahahahha
Sam. ;)
Offline Tintop
« Reply #370 on: October 21, 2013, 10:02:02 AM »
Oops....did the calc wrong ::), try 9 Sam.  Yeah 14 would be like Bear on it, or worse Terry.  Poor thing would have a hard time walking let alone jumping. ;)
77 CB550 Cafe build
  • Moderator
« Reply #371 on: October 21, 2013, 10:05:04 AM »
hahaha you've been away from the UK for to long Brian.
Offline Doctor_D
« Reply #372 on: October 21, 2013, 02:51:23 PM »
You should think about ceramic wheel bearings.  Since every bit helps here and you're not going to be running this around in the rain, get the unsealed ones and use a light oil instead of grease to lube them.
Take care,
David
1978 CX500
1971 Norton Commando
Offline sohc boy
« Reply #373 on: October 21, 2013, 04:59:33 PM »
mmmm ! yea Sam... i know what that divorce things all about , been through TWO , takes the weight off real quick ,an lots of it
  • Moderator
« Reply #374 on: October 30, 2013, 04:11:02 PM »
I didn't mind loosing the weight Pete, it was the money that went the same way that hurt. >:(
Sam. ;)
