Author Topic: Salt Racer CB 750 OZ style  (Read 169832 times)
Offline johno
Re: Salt Racer CB 750 OZ style
« Reply #425 on: November 21, 2013, 02:58:12 AM »
The other side plug, out
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline johno
« Reply #426 on: November 21, 2013, 03:02:17 AM »
This the sucker I cant get out, I made a special johno tool but it turned to #$%*e, I will drill the so and so,
I can see down the gallery to the back of the plug with a bright light and it has glass crap hard in there.
I brought a pack of Moroso cleaning brushes and man I will wear them out.
johno
« Reply #427 on: November 21, 2013, 04:37:46 AM »
I had the cases aqua bead blasted, outside looks awesome but one thing........this will be the last time I ever do it.
the galleries were just full of the glass #$%*, no matter how much detergant I used and pressure cleaners etc it didnt float the #$%* out.........I kept thinking of H2 Eric result.
Notice the plug the glass build up.
Simply if there is a dead end gallery you will not get it all out,   I got 2 out of 3 plugs out so far so I will drillt he last plug out cos I wont risk the beads.
There is an aluminum plug under the clutch cover area that will not bang out (plugs the oil galley for the transmission). The good thing is there is enough meat to drill and tap for a 6mm socket head and copper crush washer. The rubber plug opposite (under the transmission cover) can easily be removed allowing full access to that galley for a good cleaning.
  • Moderator
« Reply #428 on: November 21, 2013, 06:38:49 AM »
A lesson learned.....try ultrasonic cleaning next time perhaps.
Sam. ;)
Offline johno
« Reply #429 on: November 21, 2013, 01:29:13 PM »
Thanks Mike, I will have a play tonight. ;D    with the gallery I mean ;)
Offline cbornotcb
    • Photobucket link
« Reply #430 on: November 21, 2013, 05:29:12 PM »
Sam. ;)
I had my head ultrasonically cleaned,,,CRAP !,,,clean, yeah, but not the cosmetic external appearance I was after,
Methinks they used a weird medium in their dip ?
Back to the shed, 2 months left to do 3 months work (BOV duct today)
Tiny
« Reply #431 on: November 21, 2013, 07:07:33 PM »
You can NEVER understatement the ability of glass bead. It can be defeated......it requires effort. Every hole has to be opened (that's what she said). Joking.
« Reply #432 on: November 21, 2013, 07:09:17 PM »
Sam. ;)
Tiny
Yeah.....check that. Just my cents
Offline Old Scrambler
« Reply #433 on: November 22, 2013, 09:21:12 AM »
Johno......I have seen the results of 3 others that sand-blasted or glass-beaded.........and it was not pretty :( :( :(
I use professional brake-cleaning fluid, brushes, rags, and then my friend at the radiator shop uses a pressurized steam-cleaner if needed. Then I rinse the insides of the cases with kerosene, let dry, tape and plug everything closed, rinse the outsides with acetone, heat to 200-degrees, paint as needed, and re-heat to 250-degrees for 2 hours.  I use Frog-tape and so far have had no melting or fires. All of this was done on the CL72 and CL77 motors where only the case-covers get painted.  Now preparing two sets of CB750 K cases to try and catch-up to you! I am thinking about skipping the paint because I see what the salt does, along with the expected extra-touches by a few wrenches...............maybe save the paint for the 'trophy' show bike phase of its life ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #434 on: November 22, 2013, 09:37:29 AM »
O clean out the main galley;
 Would a long tube of brake line like 1/8 inch work , fastened to your blowgun,, just a thought..
« Reply #435 on: November 22, 2013, 01:12:23 PM »
Sam. ;)
Tiny
This is what you want, I've seen his work first hand and it is excellent.... ;)
http://www.wetblasting.net/
Offline johno
« Reply #436 on: November 22, 2013, 02:11:42 PM »
Hi retro,
Thats what I had done.
The old pommy engines have very basic easy to clean oil galleries where as our cb 's have lots of dead end end galleries, I normally would not have done bead blasting but the finish of the water blasting was so attractive I gave it a go.
I prepped the cases as best as I could for exposure to beads, every thread on the cases I put in bolts, where I could plug I did and I even made plugs for holes.....but the water then takes the beads to places I couldnt believe , eg evan past threads with bolts in.
I am committed now but I am in for a big cleaning job thats for sure, drilling and removing all plugs , re tapping every thread ,  just wouldnt do anything with bead again.  But hey the outside looks great ! ;D
johno
« Reply #437 on: November 22, 2013, 02:18:52 PM »
The reason i linked that guy is that he does a lot of very high end restorations and has a great reputation up here, actually, people Australia wide send in all sorts of stuff including vintage Ferrari engines and the like, not to sure how he does the engine oil galleries but I've chatted to him first hand and seen his work and its top notch... I'll be using him soon... ;)  Look at the gallery, there's a sandcast engine there with lots of pics... ;)
Offline Tintop
« Reply #438 on: November 22, 2013, 02:58:00 PM »
Wet Blasting / Vapour Blasting / Aqua Blasting are all the same thing RR, and use an abrasive media suspended in water.  You'll always have the issue johno has.  The trick is in how well the parts are cleaned after.  Soda blasting is probably the safest, as it's water soluble.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #439 on: November 22, 2013, 03:46:52 PM »
Hi retro,
johno
The water blasting does leave a really nice finish. A friend of a friend in Rhode Island has a nice machine.....we did some heads and they really glisten. The pics on that website Retro provided look very, very nice too.
« Reply #440 on: November 22, 2013, 05:55:34 PM »
Make sure you clean under your balls. ;)
Offline johno
« Reply #441 on: November 22, 2013, 11:36:33 PM »
Noted 754, good idea, I'll give it a go. ;D
johno
« Reply #442 on: November 23, 2013, 02:18:15 AM »
Thats why i linked the guy above, he is meticulous and well known for the quality of his work..... ;)
« Reply #443 on: November 23, 2013, 08:14:39 AM »
Does anyone use walnut shells to blast or plastic ?
 Walnut is not that soft, but I think much kinder to engine parts if it does get in places..
Offline Doctor_D
« Reply #444 on: November 23, 2013, 01:35:10 PM »
I've used walnut.  It get the big stuff off, but just doesn't get you that etched, ready-to-paint surface that garnet or SiO2 does.
Take care,
David
1978 CX500
1971 Norton Commando
Offline johno
« Reply #445 on: November 23, 2013, 01:46:18 PM »
Had to go into the bad city yesterday   ::) and was randomly walking down a street and come across a good old fashioned speed shop, couldnt resist,  went in for a look at all the car stuff and monkey see monkey buy thing happened. Came out with a few goodies,   I dont really need them but a pair of wire twisters and stainless wire, for the axle and sump bolts, some heat cover for the fuel lines,  a longacre  good electrical ignition switch with an oil light adapter,( so Peter doesnt have to look at numbers just red light or go)  and also some tyre softener.  why the tyre softener you ask ?
Offline johno
« Reply #446 on: November 23, 2013, 01:50:18 PM »
I cant find any of this winter green stuff here in oz so I will give this stuff a go on the rubbers, has anyone used this type of stuff ? no contents on the label other than its from england where the weather is so cold they need this stuff on the street cars ;) ;D
Offline cbornotcb
    • Photobucket link
« Reply #447 on: November 23, 2013, 02:22:46 PM »
Salt makes a great tyre softener Johno, It strips the soles off one pair of BHP steelcaps for me every year !
Tiny
Offline johno
« Reply #448 on: November 24, 2013, 12:45:33 AM »
My main competitor, a la Suzuki  Finny sent me a text today and said
 " Be afraid, be very afraid I started my new engine today and it sounds nice."
Now my knees are knocking ! ;D  I gotta keep my cool and focus on speed .
johno
« Reply #449 on: November 24, 2013, 07:04:15 AM »
Your 4 (kings) beats his 3 (queens) and you have an ACE up your sleeve :) :) :)
If all goes well in the motor building department, I think your looking at 162-mph on a dry and windless course.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
