Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Ok guys so i got the impact driver and i got all the bolts off the clutch case and motor oil starts pouring out of it WTF is going on and i cant get the case off do i have to remove the kickstart thing? And why is motor oil were the clutch is?
umm lucky??show me a common dry clutch honda,or jap bike.
when you assemble the lifter plate you can use one of the case screws to manhandle the pressure plate back towards the lifter so you can start the bolts easier.
Quote from: dave500 on July 07, 2012, 09:37:33 PMwhen you assemble the lifter plate you can use one of the case screws to manhandle the pressure plate back towards the lifter so you can start the bolts easier.The clutch lifter on a 550 doesn't come in from the back of the clutch basket like it does on a 500.
