Author Topic: carb rebuid cb350f  (Read 1746 times)
Offline sam059
carb rebuid cb350f
« on: July 07, 2012, 03:16:58 PM »
I have 2 carbs leaking fuel mildly, after sitting many years, so i am going to rebuild them with new needle and seats using old floats sight unseen yet. Will replace floats as needed. Any tips on removing, rebuilding and installing. They seem pretty basic. Then i will sync once up and running again. Thanks for your time.
Offline Bodi
Re: carb rebuid cb350f
« Reply #1 on: July 07, 2012, 05:48:10 PM »
Not a big horrible job.
Removing and reinstalling the carbs will be the big pain. Disconnect the fuel hose at the petcock, remove the tank and take the cables off the carb wheel. Take notes or pictures of how they attach and the cable routing. Undo the airbox tube clamps and slide the tubes off.  Loosen the intake adapter clamps way loose. Now pry the carbs off. Using a board is good, two is nice. Once you pry one side out it tends to pop back in when you pry the other side. Hold the first side out with one 2x4 while you pry the other side with another 2x4. Using a metal tool gouges the carbs and may break engine fins. Note the routing af any hoses and vents.
Get the right screwdriver for the carb bowl screws (JIS, not Philips or Frearson or Pozi-Torque) and press the driver in firmly while turning. A bit of penetrating oil applied overnight helps in removing these without ruining them: the holes are through so you can hit the heads and the threads. The screw heads are fairly soft metal and are easy to turn into round holes especially with the wrong screwdriver. A Philips #2 driver is probably the best fit if JIS is unavailable.
Make a note of how the main jet springs go in. It's hard to put them in wrong but I've seen it done.
The floats are probably fine. Be extremely careful taking the float hinge pin out, the posts break off rather easily and that's a tough fix. Penetrating oil or PB Blaster should be used for a while if they're stiff. Note the float orientation, it is reverse of what "looks right" so many people install them upside down.
The actual float valve installation is pretty simple. You may have a wire thing holding the needle part in, no big deal there. The seat hold-down clip screw should come out easily but if it's seized treat it like the bowl screws.
You should have a new O-ring for the seat.
Changing the bowl gasket is a tricky job but probably a good idea. The aftermarket ones tend to swell up in fuel, Honda OEM ones don't do that with pure gasoline but do a bit with ethanol adulterated fuel: this makes the seal impossible to reinstall for a day or so (while it shrinks back to original size) if you have to open the carbs again. Anyway, the original O-ring seal is glued in the bowl groove. Acetone or contact cement solvent should dissolve the glue so you can clean the groove after you pull the old seal out. Auto weatherstrip adhesive is good for gluing a new seal in. I glue it in then screw the bowl on the carb with a piece of wax paper in between (cut to shape) so the seal is fully seated but the bowl isn't glued to the carb.
Set the float heights as usual.
The fuel distribution fittings between the carbs have 4 O-rings each, these get hard and crack leading to fuel leaks. Hopefully you don't have to change them: it's a tricky job even without disconnecting any linkages, and the carb balance will be disturbed.
Have fun!
Offline tomkimberly
« Reply #2 on: July 07, 2012, 10:39:58 PM »
A picture is worth a 1000 words. Here is a simple way to remove and install carbs on these bikes.
Tom
Offline tortelvis
« Reply #3 on: July 09, 2012, 07:15:32 AM »
I am doing the same job on my own CB350F carbs and despite soaking in PB Blaster I can't get the float pins to budge! I thought they came out either end, is this correct? They are not tapered pins are they?
« Reply #4 on: July 09, 2012, 07:18:31 AM »
no, they are not tapered.  let them soak longer.
breaking a post will set you back one skilled welder and case of beer  ;D
Offline HondanutRider
« Reply #5 on: July 09, 2012, 08:48:57 AM »
Using some lacquer thinner on them might help to dissolve gum on the pins (which are not tapered - they can come out of either side), but don't get any thinner on the floats if they are plastic/foam material.  Another suggestion to soften and loosen whatever is sticking, is to apply a bit of heat from a heat gun or hair dryer, just being careful again not to melt those floats.
