Author Topic: Brake problems  (Read 984 times)
mustang2003
Brake problems
« on: June 20, 2006, 02:24:30 PM »
I just started rebuilding this 78 honda cb 75f ss, the front and rear brakes do not work at all, I have loosened all the bleeders and I only get a little fluid from the left bleeder valve, also both the foot and hand pedals are like your pushing nothing, they are really soft, any ideas ??
Offline 750goes
  • it will live
Re: Brake problems
« Reply #1 on: June 20, 2006, 02:31:27 PM »
Fill up the front brake reservoir, and try and bleed one caliper at a time.. maybe some fresh fluid pumped through your brake system may help if it is not a stuck piston/s in the calipers.
MartimusPrimus
Re: Brake problems
« Reply #2 on: June 20, 2006, 02:31:37 PM »
check the pads, fluid, and lines
