Author Topic: Which front brake master cylinder kit is the correct one?  (Read 1181 times)
Offline drmeloh
« on: July 09, 2012, 01:42:18 PM »
i bought the kit for a 1978 honda cb750 which is on the bag but then when i was going to rebuild it, my cousin told me it was missing two parts to it which are pointed out with the arrows on the other photo. he rebuild his master cyinder with the kit with the arrows for a 1978 honda cb550.
but when i search for the kits, both seem to show up for both bikes. HELP!!
Re: Which front brake master cylinder kit is the correct one?
« Reply #1 on: July 09, 2012, 01:46:57 PM »
the top kit is correct for the K8. it works fine.  I installed one just recently.
the bottom kit, the small black rubber piece, is included in some kits to go on the small end of the spring.  the wire is included, IIRC, to help keep the rubber bonnet in place on the top of the plunger.  neither were in the kit i got, and i dont seem to need them.
Offline mono
  • Definitely no
« Reply #2 on: July 09, 2012, 01:48:26 PM »
the arrow on the left points to the wire which i think holds in the rubber "sleeve", which you need to remove to get out the circlip.
the arrow on the right points to an identical part in the above pic, which is just the round black thing (in a top-down view).
the pic on the bottom looks like it has an extra seal, probably to accommodate either MC - my guess is that part is slightly different on the 550 vs the 750.
I think either would work, as you can re-use the round wire.  :)
Offline mono
  • Definitely no
« Reply #3 on: July 09, 2012, 01:48:58 PM »
jinx!  flybox, you owe me a coke.
« Reply #4 on: July 09, 2012, 01:51:07 PM »
soda will kill you.  how about a beer  ;D
Offline drmeloh
« Reply #5 on: July 09, 2012, 01:56:57 PM »
i was thnking the other 2 small parts should have been included if needed on the first kit, so it should work as good as the kit on the bottom. so i'm going to use the kit i bought then. thanks a lot!!
Offline fmctm1sw
« Reply #6 on: July 09, 2012, 02:26:42 PM »
I had a fiasco when I ordered one a while back.  It was the wrong size.  I noted two sizes of pistons, 14mm and 16mm I believe.  I had a thread on it but yeah I've been burned by that before.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mono
  • Definitely no
« Reply #7 on: July 12, 2012, 08:41:30 AM »
sold!
