Author Topic: Wrist pin oiling?  (Read 1589 times)
Offline ealanm
Wrist pin oiling?
« on: July 09, 2012, 06:21:29 PM »
Neither my stock CB750 conn rods nor the Carrillo rods in my race engine have those little oil-ejecting holes that I've seen on many car engines.  How does the wrist pin get lubrication?  Presumably, the cylinder walls will get splash-oiled, but it seems odd to me that there isn't a more direct way to get oil up to the wrist pin.  Or have I missed something?
"Speed, it seems to me, provides the one genuinely modern pleasure."
--Aldous Huxley
Offline wrenchmuch
Re: Wrist pin oiling?
« Reply #1 on: July 10, 2012, 07:02:01 AM »
There's a notch in the in the sides of the con rod at the big end facing the piston . These spray oil at the underside of the piston .
CB750K1
CB750K4
Offline lucky
« Reply #2 on: July 10, 2012, 11:21:42 AM »
The piston wrist pin is not spinning, it is just a small amount of movement
« Reply #3 on: July 10, 2012, 11:51:17 AM »
The part in the piston may not move, though my piston pin bosses had holes in them for some splash feed. Then the top of the small end of the rod has a hole in it to capture some splash into the pin/small end area.
I think that's right.
« Reply #4 on: July 10, 2012, 11:54:51 AM »
Full and complete diagram and description on page II-22.  ;D
(Am I becoming a snob?)  :-\
Offline Irukandji
« Reply #5 on: July 10, 2012, 12:27:03 PM »
congratulations on your 5000th post Hondaman
which I am sure have all been top notch, including your excellent book.
sorry for the bougard post
« Last Edit: July 10, 2012, 12:30:17 PM by Irukandji »
750k3
Offline ealanm
« Reply #6 on: July 12, 2012, 05:28:38 PM »
Okay, I see that on the stock rods.  But my Carrillo rods don't have that.  They don't seem to have pin holes, either.  I can't see any way for the oil to get up to the piston, yet these rods came out of a running engine so I assume there must be a way.  I'll write Carrillo and see what they say.
--Aldous Huxley
