Author Topic: plug opinions SOLVED  (Read 5588 times)
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« on: July 09, 2012, 08:46:33 PM »
do these look a bit rich? im having ok idle, but missing under load. did a double tune at 300 miles on the rebuild. still gets to speed, feels like one cylinder is stuttering.
IMAG0800 by Skamagedon1, on Flickr
« Last Edit: July 19, 2012, 11:14:06 AM by skamagedon »
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Re: plug opinions
« Reply #1 on: July 09, 2012, 09:34:13 PM »
They all look on the lean side. #3 slightly less than the others
Offline Sdsbassist
  • Gus, Austin, MN.
Re: plug opinions
« Reply #2 on: July 09, 2012, 09:34:45 PM »
They look nice
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: plug opinions
« Reply #3 on: July 09, 2012, 09:46:16 PM »
1+
Re: plug opinions
« Reply #4 on: July 09, 2012, 09:46:22 PM »
i think they look good,how old are the plug caps and condensors?
Re: plug opinions
« Reply #5 on: July 09, 2012, 09:50:47 PM »
The porcelain is bone-white. Lean...
Re: plug opinions
« Reply #6 on: July 09, 2012, 09:58:22 PM »
ride the bike some more,they still look too new,there is soot on the inside,theyll be ok.
Offline James T Kirk
    • Moabite
Re: plug opinions
« Reply #7 on: July 09, 2012, 10:06:55 PM »
sorry if i'm hijacking but on the same topic, what do you think about these?
they have 1000mi on them. pulled them out while doing a valve adjustment  kirk out
« Last Edit: July 09, 2012, 10:12:55 PM by James T Kirk »
Offline skamagedon
Re: plug opinions
« Reply #8 on: July 09, 2012, 10:15:42 PM »
350 miles on the the rebuild.  caps are prob stock, 2 off 76 k, 2 off 77 f, matching on coils. new condensors, points.
Re: plug opinions
« Reply #9 on: July 09, 2012, 10:17:07 PM »
Those look OK Captain. If there are no running issues, I would continue on at warp speed. Engineering out. ;)
Offline skamagedon
Re: plug opinions
« Reply #10 on: July 09, 2012, 10:42:58 PM »
im a big trekkie, btw......
Re: plug opinions
« Reply #11 on: July 09, 2012, 10:51:25 PM »
Skam, your stuttering issue, plus the bone-white insulators point to a lean condition, IMHO. (waiting for someone to say "beam me up, scottly!  ;D)
Offline Sdsbassist
  • Gus, Austin, MN.
Re: plug opinions
« Reply #12 on: July 09, 2012, 11:00:17 PM »
Beam me up O'brien errrr i mean scottly!
Gus, Austin, MN.
Re: plug opinions
« Reply #13 on: July 09, 2012, 11:03:37 PM »
 ;D ;D
Re: plug opinions
« Reply #14 on: July 09, 2012, 11:41:13 PM »
no intelligent life found here,,just spark plugs,new plugs take more time to show colour,use them longer.
« Last Edit: July 09, 2012, 11:43:44 PM by dave500 »
Re: plug opinions
« Reply #15 on: July 09, 2012, 11:44:10 PM »
no intelligent life found here,,just some old farts.
Fixed it for you, Davey. ;)
« Reply #16 on: July 09, 2012, 11:58:24 PM »
« Last Edit: July 10, 2012, 12:00:45 AM by dave500 »
Re: plug opinions
« Reply #17 on: July 10, 2012, 12:10:41 AM »
The post I fixed said "just old spark plugs"; I guess my reply was just before your edit. ;)
Re: plug opinions
« Reply #18 on: July 10, 2012, 12:16:12 AM »
No. lean. (or too new)  But, you never said at what load or throttle position the plugs experienced.
Re: plug opinions
« Reply #19 on: July 10, 2012, 12:16:52 AM »
better start tinkering with your jets then skamageon.
Re: plug opinions
« Reply #20 on: July 10, 2012, 12:26:12 AM »
In the first post, he stated they had 300 miles on them...
Re: plug opinions
« Reply #21 on: July 10, 2012, 12:35:53 AM »
i think too much is read into plug reading,i think kirks look too cold,uneven colours,dirty slow circuit jets and or uneven float levels?
i wouldnt worry about them though.
Offline vaughnsmith
Re: plug opinions
« Reply #22 on: July 10, 2012, 02:07:32 AM »
Captain, she be a bit hard to tell without some more data.  I'd recommend you do a proper plug chop.  Without more data I'd only be guessing, but I think we b needing to increase the anti matter flow.
    • Moabite
Re: plug opinions
« Reply #23 on: July 10, 2012, 11:45:58 AM »
AH! i need to negotiate a deal with some miners on Rigel 12 to secure more Dylithium Crystals!
then i'll do a plug chop...Kirk Out
Offline skamagedon
Re: plug opinions
« Reply #24 on: July 10, 2012, 09:13:28 PM »
must be a wee bit lean. i commuted today and throttled it good... it starts after its warm, i can get to speed and cruise, but at mid throttle it stutters, or misses. it used to have 750 mac4-2 w no baffles, now its baffled reverse megaphones and chokes, or starves?
