Author Topic: 1976 CB750F and 76 CB750K Engine Case Swaps?  (Read 1301 times)
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
« on: July 10, 2012, 08:44:26 AM »
Sorry if this has been asked already, but I been searching all over for an answer.
I have a 76 CB750F Super Sport that I’m in the process of converting into a café racer.  As I started taking parts off, I noticed a small crack in the engine case right above the points cover.  I plan on rebuilding the engine in the future.  This guy has a 1976 CB750K upper engine case that he is willing to sell to me.  The lower case is rusted and cracked, so I can’t use it.  The upper case looks to be in good condition.  Is it possible to use this K engine case on my F?  They both are the same year and I was wondering if anyone has had any experience with this?
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
Offline afkrejci90
Re: 1976 CB750F and 76 CB750K Engine Case Swaps?
« Reply #1 on: July 10, 2012, 09:02:06 AM »
If the crack is right around the points cover, you could just have it welded?  I have a crack in mine in the same area and I'm just getting it welded up.
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline Bigsam302
« Reply #2 on: July 10, 2012, 12:26:33 PM »
Thanks!  I just may go this route.  The crack is really small and I'll look around for a good welder here in San Diego
« Reply #3 on: July 10, 2012, 09:52:40 PM »
If you're asking if you can swap the upper case from another motor onto your lower case, the answer is no, regardless of years. The cases are precision machined together as a unit.
How bad is the crack? It may not need to be welded, depending on where it is and how bad. Sometimes what appears to be a crack to a newbie is actually a mark caused during the casting process as the metal cools. Can you post a pic of the crack?
Offline splitt
« Reply #4 on: July 11, 2012, 08:51:08 PM »
Yep, scottly is correct. Upper and lower cases must go in pairs. You can't mix and match.
Offline James T Kirk
    • Moabite
« Reply #5 on: July 11, 2012, 10:18:08 PM »
the initial discussion in this link i've provided is about cam caps, however the same details of construction apply to the main bearings:
http://www.cb750c.com/modules.php?name=Forums&file=viewtopic&p=222549#222549
kirk out
Offline Bigsam302
« Reply #6 on: July 14, 2012, 08:29:20 AM »
Ok, thanks for the info.  The crack is very small.  But I am going to wait until I crack the engine open and see how big the crack is.
Offline Bigsam302
« Reply #7 on: July 15, 2012, 11:03:12 AM »
Another question...do you think if I go ahead and get the complete crankcase, I can put all of my F parts on it?  ie. head, crankshaft, transmission?
