Author Topic: 74 cb550 uber low buck build.  (Read 15475 times)
Offline stolle
    • stlhondas
Re: 74 cb550 uber low buck build.
« Reply #50 on: March 19, 2017, 09:05:36 AM »
Just thought I would stick a pic at the end of this thread with the bike pretty much finished. Enjoy...
Offline Darren Jakal
« Reply #51 on: March 19, 2017, 10:30:12 AM »
Well done! I love a good low buck build.
cheers, dj
Offline Bootsey
« Reply #52 on: March 20, 2017, 10:05:24 PM »
How has the ignition module you made performed with some miles under its belt?
Offline stolle
    • stlhondas
« Reply #53 on: March 20, 2017, 10:50:42 PM »
It worked flawlessly for about 300 miles, with stock coils. Then I replaced the coils with some low impedance aftermarket ones, the transistors couldn't handle the current and fried. So with stock coils the modules work great. Right now I'm back to points and condensers, with these coils I have, I just wanted to get it back on the road. I plan on rebuilding a better module with transistors the are designed for ignitions. Ones you find on a pamco ignition, they are relatively inexpensive.
Offline stolle
    • stlhondas
« Reply #54 on: March 27, 2017, 08:04:47 PM »
I was having an issues with a dead battery, I figured it was because I was using a 1.2 ah 12 volt battery which worked pretty well actually as long as you could get the bike started pretty quick, which most of the time wasn't an issue. Alas those times I forgot to turn the ignition on or choke it and the battery would die while I was kicking like crazy was getting annoying.
So I crammed a 7ah battery under the seat, problem solved for a few rides anyway then it was dead again. First thing I thought of was the charging system particularly the regulator, as it was the only old original part beside the stator and field coil and they checked good. My charging voltage, however was only 12.2 volts. Then I find out you can adjust the output on the regulator, awesome!
Cleaned the points in the regulator, hook up a charged battery and adjust the thing. It's now putting out 14.5 - 15 volts at or above 5k rpm, just like the manual says. There is a whole procedure outlined in the manual if anyone else is having issues with low voltage. A quick Google search should point you in the right direction, if you are interested.
Offline Bootsey
« Reply #55 on: April 08, 2017, 07:35:53 PM »
Would you happen to have any pictures & more info about the ignition module, how it's mounted & the setup etc?
Offline iFart
« Reply #56 on: April 08, 2017, 09:54:22 PM »
I'm glad this got bumped up and caught my eye. Sweet build man, props!
I'm curious about where you keep the battery and other electronics. Are they under the cowl in the back?
I'm also interested in building a circuit like the PAMCO system; were you using the TIM4 or TIM6 with the stock coils?
Offline stolle
    • stlhondas
« Reply #57 on: September 28, 2017, 07:18:14 AM »
I was using the tim-6 with stock coils, I replaced the coils with aftermarket ones and it destroyed the transistors, so fair warning it won't work with low impedance coils. The rectifier and voltage reg are under the seat cowl along with a sealed AGM 12 volt 7ah battery I also a have a module to strobe the brake light in there it's packed pretty tight. I added blinkers too and put the flasher in the headlight.
Right now I'm I'm back to the stock points and condensors and some coils I got off Amazon since one of my stock coils died, but it runs great either way.
Thank you!
Edit: you can find the same transistors they use in the pamcos online they are relatively inexpensive.
« Last Edit: September 28, 2017, 07:20:00 AM by stolle »
