Author Topic: Front fender setup  (Read 1043 times)
Front fender setup
« on: July 11, 2012, 03:25:18 AM »
Anybody has a picture of front fender on later forks?  Say 73 or 74?  I am not sure where it was attached, except the struts on the bottom.
Thank you
Re: Front fender setup
« Reply #1 on: July 11, 2012, 06:41:39 PM »
I can't post a pic, but the main mounts for the later fender are the same lugs on the fork legs where the caliper mounts. The K1's had ears on the "C" mount the left side of the fender brace bolted to, and the speedo side of the brace bolted to the lugs. The fenders are not interchangeable.
« Reply #2 on: July 11, 2012, 07:06:55 PM »
Thank you, that helps.
« Reply #3 on: July 11, 2012, 07:12:31 PM »
YW
Offline Johnie
« Reply #4 on: July 11, 2012, 08:21:28 PM »
Here is a K3 pic...
« Last Edit: July 11, 2012, 08:24:47 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #5 on: July 12, 2012, 03:44:42 AM »
Perfect, thanks!
