dont have a pic, but on my 350F the throttle cables ran in the space between the gauges and the headlight, down between the upper and lower trees(between the forks), and along the left side of the frame to where they connect w the carbs. they should not be zip tied anywhere and able to move/flex freely
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
the carbs should have 4 bowl overflow tubes exiting down to the space between the swingarm and lower case.
one fuel supply tube to petcock
any others are vent/overflows and should route towards the rear of the bike, over the airbox, and directly down to the space between the swingarm and lower case.
