Author Topic: CB400F - 466cc big bore kit on eBay  (Read 20240 times)
Offline OLDN64
  • Classic, not plastic.
« on: July 12, 2012, 04:43:24 AM »
G'day guys,
Just wondering if anyone has used one of these ?
http://www.ebay.com.au/itm/HONDA-CB400F-466cc-BIG-BORE-PISTON-KIT-NOS-NEW-CB-400-RINGS-GASKET-CB400-4-FOUR-/271012265330?pt=Motorcycles_Parts_Accessories&hash=item3f1996fd72#ht_1377wt_1398
I'm not too sure about the massive increase in bore/cylinder size on the little 400.
Does anyone know if there is much else involved ? I'm imagining that this would require at least a re-jet on the carbs, but can anyone think of anything else I should consider if they're worth the money ?
Thanks and Regards,
_____________________
Dan - OLDN64
Perth, Australia.
Offline neevo
« Reply #1 on: July 12, 2012, 05:30:02 AM »
I hear they are essentially this kit but for more money:
http://bit.ly/N8IC7w
I will be putting one of these in my 400, it will require reboring the cylinders but I haven't heard much about jetting. My assumptions would be some minor tweaks would be required.
Reports seem good about the quality/performance.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: CB400F - 466cc big bore kit on eBay
« Reply #2 on: July 12, 2012, 06:07:51 AM »
Member 'Camelman' is one of the resident experts on big bore CB400's..Maybe send him a message.  He's done the 466cc bore kits before I believe.
Offline Kwality
« Reply #3 on: July 12, 2012, 07:48:58 AM »
There are a few threads on here about theSe kits. Member Jessezm has one installed. From memory it's the largest bore that you can take out the stock barrels, and you lose the taper at the base of the cylinder, making installation a little trickier.
Search '400f performance modifications' in these forums for a good discussion on not only the big bore kit, but other mods that can be done to give the 400 more bang.
Offline camelman
  • Man... Myth... Legend
« Reply #4 on: July 12, 2012, 08:01:32 AM »
I seem to have built a reputation.  Greggo, when are you going to add a 400 to your stable?
I recommend the kits from cruzin-image. I've bought a number of his kits (non 466 kits too) and have been impressed with the quality and speed of shipping, especially for under $150 shipped!! You might find some casting marks left on the piston crowns, but nothing to be concerned with and the piston dimensions have been correct and consistent for me. You might have trouble finding a shop to bore that small of a cylinder, but they exist and others here can help find a shop if necessary.
Jetting should not change much at all with just the 466 kit. If you keep the stock intake, which I recommend, then leave the stock jets in to see how they work. You might need one step larger or smaller, but you won't require a large jet size change. I recommend carb boring by denoonsp too. That is the icing on the cake and really wakes the engine up. Jetting with bored carbs should only require a single size increase on the mains...depending.
Good luck!
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Greggo
  • Somebody's
« Reply #5 on: July 12, 2012, 08:12:09 AM »
Camelman, I seem to remember asking if you had one to sell me ;)
Offline HondanutRider
« Reply #6 on: July 12, 2012, 09:55:11 AM »
These kits seem to be listed for the CB400F.  I wonder if they would also work for the CB350F?
Offline Sparked
  • Cheaper then therapy
Re: Re: CB400F - 466cc big bore kit on eBay
« Reply #7 on: July 12, 2012, 10:43:47 AM »
Same question I was going to ask. It would make sense that you would need a set of 400f cylinders to bore out.
What other changes would be necessary to optimize the big bike kit?
How much work would be needed for the 350f head to breath properly?
Or would it be smarter to swap a full 400f top end?
What are the differences between the 350f and 400f cams?
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Offline camelman
« Reply #8 on: July 12, 2012, 12:00:17 PM »
Same cams between 350f and 400f.  The 466 kit will not fit in the 350f cylinders, but you could swap out the 400f cylinders, head and studs if you wanted.  I don't think it is worth the effort (better to just swap in an entire 400f engine), but that's just my opinion.  the 400f head does not line up all that well on the 350f setup and will require some minor modifications.
The 400F stock pistons are a good swap into a 350f cylinder.  They take the 350f liners to their very limits just like the 466 kit does to the 400f engine, but they are a huge improvement to the 350f... supposedly.
I've ported out a 350f head and it made a world of difference.  I have one coming from Rieck that was ported and rebuilt, which I imagine will provide even greater benefits.  The 350F ports weren't great, and should be cleaned up if you radically increase the engine displacement.  The next choke point is the carbs, which I'd recommend to bore out (DenoonSp is a good option for that) or replace.  Boring out the carbs and increasing the displacement will not overly tax the intake and exhaust systems, and should not require extensive rejetting work.
Camelman
Offline Sniper X
  • Resistance is not futile, it is voltage devided by current.
« Reply #9 on: July 12, 2012, 02:24:45 PM »
Isn't there only 4bhp difference between the 350F and 400F?
1973 CB350 Four, 1969 CL350 Scrambler (2) 1985 BMW R80RT.
Offline Sparked
« Reply #10 on: July 12, 2012, 05:19:17 PM »
Are there any major differences between the 350f and 400f heads?  Differences in valve sizes, flow, etc??
1972 CB350F
1982 CM450A
Offline camelman
« Reply #12 on: July 12, 2012, 06:06:29 PM »
That 4HP, if that's all it is, really are noticable.  There are some big differences between the two heads.  The 400 head intake ports are much better designed than the 350 intake ports, and the intake valve is 1mm larger on the 400f I think.
Offline mattcoff1
« Reply #13 on: July 12, 2012, 06:31:23 PM »
Hey
I used the kit from cruzin image
quality was good no problems... got it running
about a month ago
 Matt
Offline Sparked
« Reply #14 on: July 12, 2012, 06:58:26 PM »
Sounds good Matt. Dis you have to change anything with your carb set up?  Do you have a build thread for your bike?
1972 CB350F
1982 CM450A
Offline mattcoff1
« Reply #15 on: July 12, 2012, 07:02:41 PM »
No no build thread
Im still getting it dialed/broken in...
 Matt
Offline camelman
« Reply #16 on: July 12, 2012, 07:39:23 PM »
Matt, I'm interested to know how you dial in that 466 if the rest of the system is stock. Don't be afraid to go down a jet size if necessary. Larger displacement can do that.
Offline mattcoff1
« Reply #17 on: July 12, 2012, 08:01:58 PM »
http://i290.photobucket.com/albums/ll272/mattyc1_photos/400new026.jpg
Its close to stock.new muffler.k&n filters
had 38 slow jets trying 40s now
I think one size up mains
 Its only gone 100 miles
I will change oil and re do 3k checks when i get back from vac next week...
Matt
« Reply #18 on: July 12, 2012, 08:30:29 PM »
Matt - beautiful bike! BOTM nominated
Offline mattcoff1
« Reply #19 on: July 12, 2012, 08:39:47 PM »
Thanks steve o
Its big fun to ride!!!
Matt
« Reply #20 on: July 12, 2012, 08:41:53 PM »
Thanks steve o
I bet.  A 400F is in my future...
Offline crazypj
  • I'm brill, me
« Reply #21 on: July 12, 2012, 08:44:16 PM »
Haven't used a kit but I built a 490 conversion that didn't have any problems except clutch slip with stock springs
Offline Sparked
« Reply #22 on: July 12, 2012, 09:46:03 PM »
Hey PJ, What parts did you use to build up the 490cc engine?
1972 CB350F
1982 CM450A
Offline camelman
« Reply #23 on: July 13, 2012, 12:12:41 AM »
Try EBC discs with Barnett springs. It'll handle well over 60 hp with a snappy clutch grab.
Matt, that's beautiful!!!
Offline Robbnc
« Reply #24 on: July 13, 2012, 08:58:55 AM »
I just got my 466 fired up last week .  I started with 40 slow and 90 main jets and it idles and revs up real good. I won't know for sure until I can ride it and
right now I'm waiting on brake parts and I gotta paint the tank.
