Author Topic: Valve cover removal question  (Read 4701 times)
Offline coke
    • Bob and Bob Bikes and Cars and Rides
« on: July 14, 2012, 04:01:54 PM »
I have looked around in the FAQ and tried to search but search doesn't seem to work or I am too stupid to figure it out. So here is my question:  can you remove the valve cover and replace the gasket without taking the engine out of the frame on a 76 model 750?  If I can that would sure save a bunch of work. Thanks in advance
1974 Honda CB350F
1976 Honda CB750F
1977 Honda CB750 F2 SuperSport
2009 H/D VRSCAW VRod
2011 H/D Road Glide Ultra
2007 Kawi 650r Ninja
1999 HD 883 Sportster (bought back from youngest son)
1999 Kawi 1500 Nomad (given to oldest son)
Offline Bob Wessner
  • "Carbs Suck!"
Re: Valve cover removal question
« Reply #1 on: July 14, 2012, 04:08:09 PM »
Use the "Google custom search" upper-left.
I seem to recall some have done this engine-in,  but most pull the engine.
« Reply #2 on: July 14, 2012, 05:33:47 PM »
You cannot remove the head cover. But there are reports that the gasket can be changed, I have not tried.  Time for a frame kit.
Offline ofreen
« Reply #3 on: July 14, 2012, 06:24:40 PM »
Some have said you can change the gasket with the engine in the frame by removing the cover screws, raising the cover, taking the old gasket out, working the new one over the cover then underneath, then buttoning everything up.  What I haven't seen explained is how you can make sure all matching surfaces are clean for a good gasket seal, and in the process keep the stuff you are scraping off out of the engine.
Greg
'75 CB750F
« Reply #4 on: July 14, 2012, 06:25:01 PM »
No first hand knowledge but there was a thread I read by someone who did it and how. Essentially, you lift the cover as far as it will go, not much, and work the gasket into place. It the old one comes off poorly you'll have to scrape it in close quarters.
But sounds like its doable.
Offline ofreen
« Reply #5 on: July 14, 2012, 06:45:59 PM »
No doubt it is doable.  Probably would leak worse than the one replaced, tho.  The crud issue isn't addressed, either.
Greg
'75 CB750F
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: July 14, 2012, 07:16:33 PM »
That's always the problem I've had with the idea.  I have no doubt it can be done, but how much time and effort would it take to do it correctly, and would that time and effort actually be less than if you pulled the engine and did it the standard way?
Offline CycleRanger
  • No comment about being an
« Reply #7 on: July 14, 2012, 08:32:34 PM »
Trust me, any method that allows the gasket to be replaced without removing the engine can't possibly involve the work required to remove and reinstall the engine...  (Without cutting the frame.)
I had to change the valve cover gasket on my 750 a couple of months ago and I removed the engine to do so.
If I ever have to do it again I'll try damn near anything to avoid that hassle again! >:(
« Last Edit: July 14, 2012, 09:22:58 PM by CycleRanger »
Offline coke
« Reply #8 on: July 14, 2012, 09:13:42 PM »
Interesting things to think about.  I haven't found a link on here that goes to the instructions on the frame mod.  there are threads with the link to the mod but I don't think they are working any more.
1974 Honda CB350F
1976 Honda CB750F
« Reply #9 on: July 14, 2012, 09:22:13 PM »
Here is a link to buy the frame kit
http://forums.sohc4.net/index.php?topic=101832.0
And an install
http://forums.sohc4.net/index.php?topic=43997.0
I have one but have not installed yet.
Offline coke
« Reply #10 on: July 15, 2012, 08:08:37 PM »
And an install
Thanks that worked
1974 Honda CB350F
1976 Honda CB750F
