Author Topic: Adjusting the timing chain slack  (Read 3945 times)
Offline lawrence
« on: July 16, 2012, 11:02:19 AM »
It seems that something is wrong with the search function on this site. I use very broad words for various topics and have searched in all sections. I have also search in specific areas. Absolutely no results come up.
Anyway, I am trying to make sure my timing chain is adjusted properly. I followed the Clymer procedure, but the adjuster screw does not turn by itself when the lock nut is loosened as the directions say it should. I can turn the screw with a screw driver, so I do not think anything is broken. Can anyone point me toward another thread or provide some tips? Thanks
-Lawrence
Re: Adjusting the timing chain slack
« Reply #1 on: July 16, 2012, 11:18:48 AM »
kinda helps if we know what bike you are working on ::)
use the Google Custom search, BTW
Offline lawrence
« Reply #2 on: July 16, 2012, 11:55:18 AM »
Did not realize I left that out, it's a 77 cb550f. I searched google and it directed me back to threads on this site. It appears that something is wrong with the tensioner.
I know that adjustment is not supposed to be done with the engine idling, but I will see if that makes a difference. And it looks like removal and replacement cannot be done with the engine in frame. This is definitely a step in the wrong direction for the renewal of a bike that was going smoothly.
« Reply #3 on: July 16, 2012, 12:01:10 PM »
exactly what it is supposed to do  ;)
Offline lucky
« Reply #4 on: July 16, 2012, 12:12:23 PM »
DO NOT do it with the engine running if the book does not say to do it that way!!!
Do it the way the book says.
Some engines have to have the crankshaft in a particular place when the adjustment is made.
Get the right info for your bike. Do not listen to people that just say to do it when the engine is running .It can cost you a engine!!!
I amazes me how some people would risk ruining their engine and just experiment
with such a critical component.
« Reply #5 on: July 16, 2012, 12:17:36 PM »
Yeah I didn't want to give up the old Search, but I'm learning the Google Custom Search actually works pretty well.
Offline modzsquad
  • Old Honda owners don't die...just get restored
  • Stop at Lake Santeetlah Tail of The Dragon
    • My gallery
« Reply #6 on: July 16, 2012, 12:19:17 PM »
I was just reading my repair manual, (spare time and remember that the cam should be adjusted with the #1 piston Top dead center!
Jim Modzelewski
Offline Fritz
« Reply #7 on: July 16, 2012, 01:07:54 PM »
I hope you mean to adjust the cam (not the chain) at #1 TDC.
The cam chain should be adjusted with the bike warmed up 15° after TDC of #1:
Open the nut on the cam chain adjuster.
Turn the crankshaft until both valves on #1 are closed (rockers should be free). Turn the camshaft further until you see the advancer peg and line its left side with the timing mark on the engine case.
Now you should be able to turn the adjuster screw about 45°-90° clockwise. You should feel the resistance of the spring. The screw should snap back into the initial position if you let loose.
You should not be able to turn it counterclockwise more than maybe 5°.
Now let the screw turn itself back into position, hold it there with the screwdriver and tighten the nut.
It's all explained in the Workshop manual available at http://www.sohc4.net/index.php/cb550/books-manuals-guides-2/
Part 1 – Repair Procedures, Tools, Maintenance Operations
« Last Edit: July 16, 2012, 01:12:36 PM by Fritz »
1976 CB550F
Offline Deltarider
« Reply #8 on: July 16, 2012, 01:08:24 PM »
Bryanj's way is best.
BryanJ's patented "many years in the trade" method for tensioning the camchain!
Follow the manual as far as positioning the engine with #1 cylinder 15 degrees before Top Dead Centre (TDC). Loosen the locknut and put pressure on the crank so that it's just about to turn, either with the kickstart OR with a big spanner on the big nut on the auto advance so that all the camchain "slack" is at the back and then, whilst holding the pressure get your mechanically trained spider to tighten the locknut.
Been doing that on ALL OHC Hondas for 30 years and as long as the tensioner moves and the chain isn't worn out its guaranteed to work.
CB500K2-ED Excel black
« Reply #9 on: July 16, 2012, 01:13:02 PM »
Agreed!
...training the spider takes a while though  :o
Offline Fritz
« Reply #10 on: July 16, 2012, 01:15:01 PM »
Agreed!
Yes, pushing all the slack to the back is nice. But it's 15° after TDC ;)
1976 CB550F
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #11 on: July 16, 2012, 01:20:16 PM »
And do not follow the Clymer manual procedure in technical matters, it is only good for light, non-tech summer reading.
Offline Deltarider
« Reply #12 on: July 16, 2012, 01:35:05 PM »
I've made the same comment long time ago.
Anyway, Bryanj will react by saying: it doesn't matter what the @$# position it is in, as long as you apply that pressure on the crank.
Offline DJ_AX
« Reply #13 on: July 16, 2012, 01:43:30 PM »
Interesting... so you're both right.
The reason just past tdc is recommended is that the compression in the chambers keeps the tension on the front of the chain.
« Reply #14 on: July 16, 2012, 02:06:12 PM »
I don't think that its the compression in the chambers keeping the tension, as it is often set with the plugs out.
Its the pressure of the valve springs holding the cam backwards, tension on the front, right at that point.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: July 16, 2012, 02:06:35 PM »
And FWIW on the CB550, the cam tensioner screw is counter-clockwise to tighten chain, clockwise to loosen. But GO EASY......
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline DJ_AX
« Reply #16 on: July 16, 2012, 02:23:42 PM »
i c :)
