Author Topic: Orig. Footpeg Problem  (Read 1282 times)
Offline mronegear
  • Honda CB 550 F 1976
« on: July 16, 2012, 12:33:58 PM »
Hey all!
I ride a cb 550 F (1975) and i want to go back to the original front footpegs. I was riding with raask footpegs so far.
The problem is that the left front peg (shifter side) is mounted by the lower engine mounting bolt through the frame.
If i loosen that bolt to install the left footpeg, the frame realeases a bit and the bolt + footpeg doesnt fit any more by just 2 or 3 millimeter. So there is no way to get the nut back on the bolt with the footpeg.
Is there any way to solve this problem without having to uninstall the exhaust system (4-1) to rope in the frame somehow?
I'm thankful for tips and tricks!
cheers
Re: Orig. Footpeg Problem
« Reply #1 on: July 16, 2012, 08:04:46 PM »
Hey all!
cheers
Unless someone has swapped that frame bolt for a different one, there should be enough length available. Maybe there is a spacer on the other side. or something?
Offline luap
  • LAWL
« Reply #2 on: July 16, 2012, 11:25:48 PM »
did you loosen both nuts to be able to pull more threw the side your having problems with with the stocker pegs- should have 7ish threads on either side
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline mronegear
« Reply #3 on: July 16, 2012, 11:47:24 PM »
There is def no spacer or anything on the other side, only that distance plate inbetween Motor and frame.
In my case there is only 1 nut to loosen, the other one is one with the bolt.
I will check if probably one preowner used a different bolt, maybe from 550K?
There should be normally enough space for the orig. footpeg and this bolt is damn short. Something must been wrong with it.
thanx
Offline mronegear
« Reply #4 on: July 17, 2012, 12:15:18 AM »
The preowner painted the frame. he might have swiched the upper engine mounting bolt with the lower one?!
Is the upper bolt a little longer? I only need 5mm more lengt to install the peg...
thanks,
Schuster
Offline harisuluv
« Reply #5 on: July 17, 2012, 12:18:41 AM »
I am just finding out that these footpegs seem to be different than the ones on my 550k (working on a 550F now) I am looking for these pegs.
Offline mronegear
« Reply #6 on: July 17, 2012, 10:08:56 AM »
Ok, today i ordered a new bolt for my bike to check if it will work with this.
And i was lucky, cause there were only 3 original bolts left in stock! I really hope it will work, and will report after
i got it!
cheers,
Frank
Offline mronegear
« Reply #7 on: July 23, 2012, 02:03:27 PM »
Problem solved!
the new org. bolt is longer than the old one and the footpeg is fitting nicely  ;) ;) ;)
so the preowner took a wrong bolt  >:(
cheers,
Schuster
