Author Topic: Summary of differences - 1976, 1977, 1978  (Read 4883 times)
Offline farmertom
  • Owner of many cb750s
  • MBS - anonymous
« on: July 16, 2012, 07:00:52 PM »
Hi all,
Has anyone put together a list of the differences between the model years for the Hondamatic?
I've got a '76 next to a '77, and am seeing all kinds of things that were changed for '77 --
Frame
Triple-clamp top / ignition switch shroud
Wire loom
parking brake
battery box
etc.
Does this site have any place set aside to show pictures of the differences?
The '76 had a mish-mash of parts from other bikes when I got it, and I'm trying to make it more true to stock.
I'd like to see a picture of the face of a pilot  gauge from a '76 to compare to the '77.
Was the chain size the same?
Were the DID alloy wheels the same?
...so many questions....
I've gone to the Western Honda site and looked at the fiches, and noticed all sorts of part number changes, but the fiches don't show what a real color photo does.
'76 cb750a
'77 cb750a
...and many K's
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Summary of differences - 1976, 1977, 1978
« Reply #1 on: July 16, 2012, 08:21:50 PM »
This thread could be that list!
Wheels - spokes in 1976 and 1977; Comstars in 1978.
Carbs differ - each year is different.
Idle pull-off - 1976 works at all speeds, 1977 and 1978 shuts off above about 16 MPH.
Caster angle - 1976 differs from 1977 and 1978 (which are the same).
Sprockets - 1976 differs from 1977 and 1978 (which are the same).
Plugs - 1976 differs from 1977 and 1978 (which are the same).
Gear indicator - 1976 and 1977 are the same (L for low and D for drive), 1978 differs (1 and 2).
Chain - 1977 and 1978 were o-ring, 1976 was not.
Parking brake mechanism - 1976 differs from 1977 and 1978 (which are the same).
Engine stop switch - 1976 differs from 1977 and 1978 (which are the same).
Turn signal, horn, dimmer switches -  1976 differs from 1977 and 1978 (which are the same).
Brake disc - 1976 and 1977 are the same, 1978 differs.
Speed drive - 1976 and 1977 are the same, 1978 differs.
Front brake hoses - 1976 differs from 1977 and 1978 (which are the same).
Master cylinder - 1976 differs from 1977 and 1978 (which are the same).
Wiring inside handlebars - 1976 only.
Seat - 1976 has a somewhat flat seat, 77/78 have a stepped seat
Handlebars - 1977/78 have higher bars then 76, cables are different length.
Front emblem - 1976 HONDA emblem on forks is different
1977/78 uses a speed warning unit on the throttle opener
1976 uses a fork mounted brake switch, 77/78 is mounted on master cylinder
The Seat has a strange grabrail built in the 1976 model.
1976 model has a 4 into 1 exhaust like a CB750F - 1977/78 has 4 into 2.
1976 kick start lever is unique to 76.  However, the 77/78 kick start lever will fit all three years.
more to come . . . .
« Last Edit: April 16, 2014, 08:46:45 PM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline farmertom
  • MBS - anonymous
« Reply #2 on: July 25, 2012, 11:21:34 AM »
Toolbox on bottom rear of seat is fastened differently.
Petcock on '76 - outlet points to side - in toward carbs.  '77 points to rear.
'76 cb750a
'77 cb750a
...and many K's
Offline 77Pinto
« Reply #3 on: July 27, 2012, 04:45:36 AM »
My 78 pointed to the center of the bike, until I put a new aftermarket one on.
Carb.s: The bowl vents are all connected and have a breather tube that is attached to the top of the air box on the 78s. On the 77 I worked on for a friend each carb had a vent on the side of the casting.
Bill
Offline stevematic
« Reply #4 on: August 02, 2016, 01:58:28 PM »
76 to 77 the exhaust clamps and seals to the head changed from a flange clamp to a sleeved clamp.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: August 02, 2016, 03:27:02 PM »
There's basic model information right here on this very site:
http://www.sohc4.net/cb750a/
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline jukku
  • Happy with my Hondamatic
« Reply #6 on: August 04, 2016, 10:37:18 AM »
Different chain sizes.
1976   CB750A Hondamatic   530x104
1977 & 1978   CB750A Hondamatic   630x88
