Author Topic: Anyone Know Anything About This GS 750 ES (pics) ???  (Read 1772 times)
Offline Johnie
« on: July 17, 2012, 09:26:56 AM »
This is a 1983 Suzuki GS 750 ES with title and 14,000 miles which was last run 2 years ago. I have a line on the bike, but am just starting to check into info on the bike. It is not listed for sale, but a friend owns it and wants me to consider it. Motor turns over fine. Anyone know much about this model which appears to be in very good condition minus the dust. Looks like an oil change and good cleaning is all it needs. Thanks for your expertise...
« Last Edit: July 17, 2012, 09:31:35 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Anyone Know Anything About This GS 750 ES (pics) ???
« Reply #1 on: July 17, 2012, 09:37:59 AM »
Check carefully, I seem to recall certain early Suzuki clutches have friction plates that are no longer available from ANY source.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: July 17, 2012, 09:55:41 AM »
My brother had one, all I remember was it was nice and sporty.
Offline kirkn
« Reply #3 on: July 17, 2012, 11:03:51 AM »
Outstanding machines, IMO.
Charging system issues with most of the bigger inline-4 Suzukis of that era, but well documented and easy enough to correct / fix.  Might even have been corrected by the OEM by that time, but I can't recall for sure.
Huge support over at http://www.thegsresources.com/_forum/index.php  including manuals, wiring diagrams, parts lists etc.
The ES was the sportier of the two models.  The 'E' model was more standard - higher bars and no fairing.  DOHC, 4-valve per cylinder heads, screw-and-locknut valve adjusts.  Triple disk brakes and Suzuki's early-80s hydraulic anti-dive built into the front suspension.  Kinda a gimmick, but effective.
I had the 'tariff-beater' GS700E of '85 which was essentially the same bike but with a smaller bore and slightly hotter exhaust cam (to try and make up for those 50cc).  Great bikes!
If the price is right, I'd go for it in a minute with no hesitation!
Kirk
  • 1977 CB550F2
« Reply #4 on: July 17, 2012, 11:11:08 AM »
There was also the ESD which had a full fairing.
« Reply #5 on: July 17, 2012, 03:54:18 PM »
+1, excellent engines and not a bad handling bike at all, I had one in the 1980's and it was a great bike...
Offline Xnavylfr
« Reply #6 on: August 01, 2012, 03:35:37 PM »
Looks like it needs a REAR tire!!! Someone has SMOKED that one!!!
Xnavylfr(CHUCK)
