Author Topic: lacing cb750 wheels  (Read 11551 times)
bollingball
Re: lacing cb750 wheels
« Reply #25 on: July 21, 2012, 08:55:07 AM »
I don't know where the idea of a cross 4 came from.
I do ::)
Quote lucky When you look down at the wheel and you look at a spoke it must cross over 4 other spokes.
Ken
« Reply #26 on: July 21, 2012, 09:00:29 AM »
I do ::)
Ken
I can't tell if there is sarcasm or humor involved here.
I was trying to be polite.
Lucky called it a cross 4 for some other reason, group of 4 or whatever.
The terminology of "cross this or that" has to do with the number of inside spokes an outside spoke will cross. On a CB750 front wheel its 3, on the rear its 2.
Offline Old Scrambler
« Reply #27 on: July 21, 2012, 03:17:05 PM »
When you lace your own wheels you tend to sit a little taller at the bench-racing sessions........just remember to check for loose spokes after a few miles.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline lucky
« Reply #28 on: July 21, 2012, 03:25:27 PM »
I do ::)
Ken
That is just the way I was taught.
There are other spoke patterns also that you see on show bikes.
Offline pitpig
« Reply #29 on: August 06, 2012, 07:14:55 PM »
Don't know if this helps, but I had great success by dropping all the inners at the same time into the hub.  It was easier to visualize where they went in each group of four.  Took me a day to figure out that there are groups of four dimples that point inboard around the rim.  Installed all the inners without flipping hub over, once you get that figured out, the outers are easy.
