Author Topic: CAR Headlight De-Fogging  (Read 1084 times)
Offline Accolay
« on: July 19, 2012, 02:53:58 AM »
I accidentally found that wiping a bit of MEK across plastic foggy headlight lenses seems to clear them up quite well. Just be careful that you don't try it another time immediately afterwards because the solvent has done its job and if you wipe them again it'll be like wiping across drying paint.
It seems to clear them up really well, and for me, a cheaper and quicker solution than buying one of those kits. No idea how long it will last before they get foggy again, but I'm satisfied for now. Of course, the clear coat on my '96 Civic is peeling off, so I don't really care about the paint. If you try this, you might want to tape off your car first.
1977 CB550F
Re: CAR Headlight De-Fogging
« Reply #1 on: July 19, 2012, 01:03:24 PM »
Good to know.
I originally bought one of those 3M rotory tool headlight treatment kits, just for the sponge/foam pad to use as polish/swirl remover applicator for my tank and side cover paint i had done.  turned around the next week and used the rest of the kit on the wifes car headlights.  worked well.
Offline Spanner 1
« Reply #2 on: July 19, 2012, 07:00:42 PM »
Toothpaste  :o.... just give it a try with a rag and rinse -off.....  ;D... works great.
Offline Accolay
« Reply #3 on: July 19, 2012, 08:26:53 PM »
That would require elbow grease  :P
1977 CB550F
Offline wardenerd
  • '77 550F '81 650C
« Reply #4 on: July 20, 2012, 07:58:23 AM »
i use the 999 disposable from Harbor freight.  Use the drill for 6 minutes instead of 3 for best results.
Offline Raul CB750K1
« Reply #5 on: July 25, 2012, 04:32:56 AM »
Just a FYI, don't know whether it is true, but I head that the reason for the car headlights to get dull with time is for using low-quality -read "chinese"- bulbs. It seems that the good ones has some kind of filter in the glass to prevent UV being projected.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: July 25, 2012, 08:17:59 AM »
Funny right after I painted my tank and buffed it out I took the DA buffer and the anti-swirl compound and tried it on my wife's Honda Civic HL lenses. They are notorious for headlight lens gloom. It worked great. I also have some 3m Imperial compound that worked like a charm on my boat's chalky gel coat I might try that next.
"the reason for the car headlights to get dull with time is for using low-quality -read "chinese"- bulbs"
I kind of doubt it because the crud is on the outside of the lens, the bulb is on the inside.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #7 on: July 25, 2012, 09:28:55 AM »
As I said, it is just something I heard and maybe it is just BS, but as we are talking reactions to some kind of radiation, it wouldn't mind much whether it is on the inside or the outside where the sensitive material is.
You probably have noticed that, wherever you use fluorescent light, appliances plastics -like old computer's keyboards, monitors, or kitchen appliances- turn to yellow with time. If it was a glass in between, it wouldn't make any difference....
« Reply #8 on: July 25, 2012, 09:52:41 AM »
when car headlights are like this gals teeth :o you need a little more than toothpaste and a wet rinse. 8)
