Author Topic: CB750 Idle issues  (Read 37180 times)
Offline Spanner 1
Re: CB750 Idle issues
« Reply #75 on: August 15, 2012, 11:06:38 AM »
I've expressed my opinion about your 30 day thread, that's all..... have a nice day  :)
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« Reply #76 on: August 15, 2012, 12:05:09 PM »
Getting the carbs back on. This is my method.
Put a tiny bit of Vasoline speared on the mating parts.
Get on the right side of the bike and tie the carbs up with zip tie to take the weight off.
Then push the #4 carb into position all the way and tighten the clamp.
Then go to the left side of the bike and push the #1 carb into position all the way.
Tighten the clamp.
The two middle carbs should take care of themselves.
Thanks, Lucky!  This method worked nicely...
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline lucky
« Reply #77 on: August 15, 2012, 12:34:38 PM »
Tighten the clamp.
You are welcome Brycegp!
Offline brycegp
« Reply #78 on: August 15, 2012, 08:07:16 PM »
Offline persson-johan@hotmail.com
« Reply #79 on: April 29, 2016, 02:42:47 AM »
Were did you get that nice brass screw with the hose adapter that you can see on the first pic?
« Reply #80 on: April 29, 2016, 11:16:16 AM »
I hope I am not wasting my time again.
lol...The OP has not been on in nearly 2 years.  Pretty sure he's figured it out or moved on ::)
Last Active: September 20, 2014, 06:15:14 PM
Offline lucky
« Reply #81 on: April 29, 2016, 11:17:40 AM »
Thanks Flybox1!! You are quick!!!
Offline bomorr
    • sohc/4
« Reply #82 on: October 26, 2016, 07:40:25 PM »
and here I was reading the entire 9 pages trying to see if anyone had info on the adapter this guy used on his float bowls... lol I won't hold my breath
Sent from my SM-G925V using Tapatalk
