Author Topic: 1974 cb550 ignition coils  (Read 1427 times)
Offline xjonathanx
« on: July 20, 2012, 10:01:41 pm »
I discovered the other day my #1 cylinder was firing right, causing the right side of my carb to flood like crazy. Thought that maybe it was my spark plug, it wasn't. Touched all four of my exhaust pipes and the #1 pipe was cold. Took out the soak plug and kept it plugged to the wire and turned my bike on, there is no spark at all, but my #4 plug does spark. Is there an easy fix? Are my coils just bad, and if they are can someone direct to a website I can order some new ones please.
bollingball
Re: 1974 cb550 ignition coils
« Reply #1 on: July 20, 2012, 10:19:28 pm »
The caps come off screw them just like you would a nut/bolt. When you  get it off if it is long enough cut a 1/4 in off to get to clean wire.
Ken
« Last Edit: July 20, 2012, 10:38:31 pm by bollingball »
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #2 on: July 20, 2012, 10:35:11 pm »
Agree it could be the wiring, but if you verify bad coils, I put Dyna's 5 ohm coils (and new plug caps and wires)on my '74 550 and it made a huge difference in performance. Good luck.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: July 20, 2012, 10:55:36 pm »
Just swap 1 & 4 caps over & see if the misfire follows the caps. Maybe that simple.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
