Author Topic: Cb500 float bowl oring size....!!!!!????  (Read 3053 times)
Offline ericmu17
« on: July 21, 2012, 12:46:43 PM »
I honestly cant find this anywhere on the internet. I noticed that this site offered the main jet and float valve assembly sizes but not the oring for the gasket.
Offline tewolf24
Re: Cb500 float bowl oring size....!!!!!????
« Reply #1 on: August 09, 2012, 09:04:05 PM »
I was able to order individual o-rings from theoringstore.com and fit all the o-rings as follows
needle jet - 1.5mm x 5mm
main jet - 1.2mm x 3.5mm
bowl drain screw - 2mm x 4mm
float bowl - 2mm x 68mm (really needs 68.5mm though)
fuel feed tee - 2mm x 7mm   hope this helps
« Last Edit: August 19, 2012, 08:46:57 AM by tewolf24 »
Offline phil71
« Reply #2 on: August 09, 2012, 09:10:08 PM »
aren't those float bowl gaskets shaped like a house?
Offline phil71
Offline JamesM
« Reply #4 on: August 10, 2012, 07:08:23 AM »
^ CB500Ks are just o rings.
http://www.partsnmore.com/parts/honda/cb500/?filters%5Bfitting%5D=custom
Part Number: 20-8032
$3 each.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline mjstone
  • I'm definitly not a
« Reply #5 on: August 11, 2012, 06:43:06 AM »
You can get shaped carb bowl gaskets, but they're pricey.  Put a set in my '73 CB500.  Made the install a breeze and no leaks.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
« Reply #6 on: August 11, 2012, 08:58:21 AM »
I bought this set of 4 for a CB500 awhile ago from this Guy. He has free shipping if you read down and they came fast. Have not installed them yet though so no report on that. http://www.ebay.com/itm/CB500K-71-73-CB550K-74-76-CB500F-75-77-KZ750-Carb-Float-Bowl-Gaskets-SHIPS-FREE-/150836620430?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item231e902c8e
