Author Topic: Why am I getting these spots on the upper forks?  (Read 1430 times)
Offline messeduptriple
« on: July 21, 2012, 05:12:03 PM »
I get these lil spots only on the upper forks between the light clamp and the triple.  Why?  What is causing it?  If I rub with t shirt it comes off bit it's only on this area.
Sent from my MB855 using Tapatalk 2
Offline knowsnothing
Re: Why am I getting these spots on the upper forks?
« Reply #1 on: July 21, 2012, 06:24:21 PM »
Maybe something has a slow leak and the wind is splashing it there.  Check that banjo and anything else in the area
1978 CB750k Blue - for sale
« Reply #2 on: July 21, 2012, 06:55:42 PM »
Same on both sides ? Almost looks like a light surface rust. Are the spots wet or dry. Maybe some car wax if its a little flash rust.
« Last Edit: July 22, 2012, 03:59:05 AM by ekpent »
Re: Re: Why am I getting these spots on the upper forks?
« Reply #3 on: July 21, 2012, 08:18:44 PM »
Same on both sides ? Almost likes like a light surface rust. Are the spots wet or dry. Maybe some car wax if its a little flash rust.
yes both sides.dry. ill check tonight banjo. Not sure why car wax? ? I dont use that
Offline lone*X
« Reply #4 on: July 21, 2012, 08:27:25 PM »
Maybe follow the recommendation, wax the tubes, and you won't get those rust spots.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline phil71
« Reply #6 on: July 22, 2012, 12:54:46 AM »
brake fluid drip.
Offline trueblue
« Reply #7 on: July 22, 2012, 04:23:43 AM »
Bugs eat chrome and cause rust, keep a little wax on them.
1979 CB650Z
Offline kpier883
  • is quite the
« Reply #8 on: July 22, 2012, 06:07:11 AM »
Water is accumulating elsewhere and getting rust colored from the rust formation that is occurring in the area in which it is gathering.  Then when riding, wind is blowing it out of its hiding place and leaving those spots where it hits and dries.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #9 on: July 22, 2012, 08:52:37 AM »
 What bike? on a lot of years the portion of forktube that the seal does not ride on is not plated, then they will rust.
Dont like the wax idea, use grease or paint...
« Reply #10 on: July 22, 2012, 12:29:33 PM »
76 550
« Reply #11 on: July 22, 2012, 12:30:09 PM »
banjo is tight
« Reply #12 on: July 22, 2012, 12:43:12 PM »
Upper fork tubes are notorious for rusting. Anybody who has removed their forks or headlight ears has seen that mess underneath.
